Latest: Kifi69
Overall: 17183
Online Now [345]:
Visitors: 344
Today: 52622
Total: 143601341
Forums › The Car › 206 Talk › 206 1.6xsi ecu location?
actionman
PostPosted: Fri Dec 23, 2011 5:53 pm Up
Hi
does anybody know where the ecu is located on a 2003 206 1.6xsi?
thanks
Craig
Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes!
PostPosted: Fri Dec 23, 2011 8:37 pm Up
Open the bonnet, if you cant spot the ecu make an appointment at the opticians Laughing
-Dave-
PostPosted: Sat Dec 24, 2011 1:15 am Up
Trade Rating: +36
Left hand side under the bonnet. Can't miss it. Something I though you would know with you offering the services in your sig.
Ex 206 Owner.
PostPosted: Sat Dec 24, 2011 5:49 am Up
You don't need to know where a ECU is if you flash via obd, although it doesn't fill you with confidence
actionman
PostPosted: Sat Dec 24, 2011 8:26 am Up
thanks guys. Never done any ecu/remap work on a 206 & haven't looked under the bonnet of the xsi yet.
It's not for a remap neither btw. Customer says it may need replacing. So i'll find out when i get there next week
funnily enough i've serviced a 1.4 this morning & noticed the ecu in the engine bay
actionman
PostPosted: Sat Dec 24, 2011 9:02 am Up
just because of what i do for a living it doesn't mean that i know everything about every car or have worked on every car! Wink I've had very little to do with Peugeots in general
PostPosted: Sat Dec 24, 2011 9:29 am Up
You replacing the bsi unit if your using a second hand ECU?
-Dave-
PostPosted: Sat Dec 24, 2011 9:35 am Up
Trade Rating: +36
That wasn't meant as a dig pal. I would just be worried about messing with things like that if I didn't even know where they were. From what I gather swapping the ecu from one car to another is not that simple.
Ex 206 Owner.
PostPosted: Sat Dec 24, 2011 9:39 am Up
As im hanging
Yes is the answer
PostPosted: Sat Dec 24, 2011 9:52 am Up
You don't need to swap the BSI as he should be able to do epprom work.
PostPosted: Sat Dec 24, 2011 10:21 am Up
Surely if he using a second hand unit (replacing keys, immobolisier, etc) and not rebuilding the original then this would require a swap Smile
actionman
PostPosted: Sat Dec 24, 2011 10:36 am Up
well the lad said he'd seen another ecu with all the relevant parts needed inc 2 keys for a reasonable price
He's only got 1 key as it is so with the cost of possibly repairing his ecu then getting him a new key he said it may work out cheaper for him to buy a complete 2nd set off of ebay or something as he says he'd just swap everything over himself apart from the locks as he'd just keep the originals then i can cut him another blade to go with his 2nd remote
He just wants me to take a look at the ecu & see what i think would be the best option
i've got 4 different bit of equipment that should be able to talk to his ecu. I'll just see how it goes when i get there after xmas
PostPosted: Sat Dec 24, 2011 10:53 am Up
You can't swap immo via obd
You need bdm
And you don't need a BSI, new keys etc if you can do epprom work. Just change the eeprom. I got three sorted now for under £120.
If you can remap and it's just the chip you flash with k-line that's f***. Fit a new chip and flash with org dump.
If you can't flash with bdm, you shouldn't be remapping.
