Latest: S2cgm
Overall: 17178
Online Now [72]:
Visitors: 72
Today: 2383
Total: 137432232
Forums › The Car › 206 Talk › Engine weight difference
HDI90
PostPosted: Thu Dec 29, 2011 12:04 pm Up
Im just after the weight difference between a 2.0 petrol and diesel, as ive just got hold of some 25mm eibach springs and shocks from a GTI
so in theory if the diesel has more weight the car will be lower than the 25mm?
GTI 180
Mattie-RS
PostPosted: Thu Dec 29, 2011 12:08 pm Up
the diesel is the heavier
PostPosted: Thu Dec 29, 2011 12:11 pm Up
What He Said
think the EW10 is aluminium block while the DW10 is cast iron block
Rob2859
PostPosted: Thu Dec 29, 2011 12:12 pm Up
I wouldn't expect a big difference. Remember the springs need quite a while to settle too.
PostPosted: Thu Dec 29, 2011 12:18 pm Up
Mine didn't settle ever. Lowered it exactly 30mm and stayed there.
The Pro Kit springs are for the 1.4HDi and GTi aren't they?
HDI90
PostPosted: Thu Dec 29, 2011 12:22 pm Up
Yes but the ones i got are for the GTI
GTI 180
PostPosted: Thu Dec 29, 2011 1:25 pm Up
decent spring shall not take time to settle Confused
PostPosted: Thu Dec 29, 2011 1:28 pm Up
Some EW10 are cast other are alloy
PostPosted: Thu Dec 29, 2011 1:30 pm Up
when did they change over? Shocked
Mattie-RS
PostPosted: Thu Dec 29, 2011 1:31 pm Up
basically your going to get 27mm if that!!
PostPosted: Thu Dec 29, 2011 1:32 pm Up
I'll try and have a look, might be the whole RFN/RFR thing. Off the top of my head the serial number is in a different place on the alloy to the cast
PostPosted: Thu Dec 29, 2011 1:47 pm Up
All EW10 engine are alloy. RFN/RFR just means the addition of a 2nd lambda sensor.
PostPosted: Thu Dec 29, 2011 2:04 pm Up
I've definitely read on servicebox some are alloy and some are cast.
