Latest: sparrowdclxvi
Overall: 17139
Online Now [81]:
Visitors: 80
Today: 25428
Total: 112651922
Forums › The Car › 206 Problems › Gear stick wobbles badly in 4th...
Mike_XS
PostPosted: Thu Dec 22, 2011 1:39 pm Up
So yeah, just started doing it. As I accelerate through the gears, everything is normal until I get to 4th gear. The gear stick starts wobbling side to side quite badly and I can feel it through the car. Also, if I rest my foot on the clutch, I can feel movement on that too. As soon as I change into 5th, it stops. Any ideas? I have a 5 hour drive on Saturday that I don't have a choice but to do...
Mrs_Howey
PostPosted: Thu Dec 22, 2011 5:54 pm Up
Might be a long shot but it could be the gearbox, it might be wobbling if 4th gear has lots of wear on it, is 1st and 5th fine?
As i had gear stick wobble when my new tyres went on, which has now stopped but i think it's now whinning
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Thu Dec 22, 2011 6:13 pm Up
looks like the bearing has gone
Mike_XS
PostPosted: Fri Dec 23, 2011 12:46 pm Up
After driving it today, I have discovered that its not just 4th it does it in. It seems to just do it between 50-60mph. As soon as I get over 60, it stops...
Maybe a silly question, but, which bearing?
jsmalls
PostPosted: Mon Apr 09, 2012 1:45 pm Up
Hi
Just noticed the same thing in my car. Seemed to happen after it's MOT at which the CV boots (not joints) were replaced. Wobbles like mad between 50-60mph and worse under acceleration. It wobbles more than it used to at other speeds but not anywhere near as bad as at between 50-60. It happens whether in 4th or 5th.
Did you ever find out what it was? ...was it expensive to fix...?
Cheers
206 1.4
djmatrix
PostPosted: Sat Sep 01, 2012 3:53 pm Up
Having same problem at around 40 / 50 mph ? .. can feel the whole car wobbling at said speed ... anyone can help please ? Sad
Deckchair5
PostPosted: Sat Sep 01, 2012 4:09 pm Up
Wobble at 50mph is often a characteristic of a wheel out of balance or a bulge in a tyre
