Latest: tbafonso
Overall: 17130
Online Now [213]:
Visitors: 212
Today: 69688
Total: 104259304
Forums › The Car › 206 Talk › head gasket/cambelt price+renewal
greenpug2222
PostPosted: Sun Dec 25, 2011 10:27 am Up
Hi all,
I have the water behind the glove box thing and you have all told me i need to get the head gasket done..... so ive phoned around........
Most places want around 400-500 quid but one place and i must stress it is a friend of a friend but not mates rates has said around the 300 mark. This is to replace gasket,send head away for pressure testing and a skin if needed, cambelt renewal and fitting back together again.
Im thinking this price is good and need to ask you all is there anything i need to ask when i call him to give them the go ahead as the price has been relayed back to me from my friend.
All help appriciated
why wont you work??????????????????? ARGH F**k it!!!!!
PostPosted: Sun Dec 25, 2011 10:37 am Up
I would get confirmation from someone that knows that there doing that the head gasket is indead faulty first.
You can get the running water sound from the heater matrix if the cooling system hasnt been bled correctly.
greenpug2222
PostPosted: Sun Dec 25, 2011 11:28 am Up
oh i see......... well the coolent has not been changed by myself for the year ive had it and i am loosing coolant from the expansion tank through i think pressurization as i can see it wet all around that area and also on the tank itself. The car also has a funny fit when i start it from cold for the first time say in a morning...... its as if the engine shakes and does not want to bun its fuel....this shakes the car but only for approx 5-10 seconds then its fine...
starkie
PostPosted: Sun Dec 25, 2011 12:20 pm Up
sounds more like it needs a good service to me.. and a seal/new rubber somewhere.. check under the oil cap for milky type substance to check head gasket
Starkie =]
greenpug2222
PostPosted: Mon Dec 26, 2011 6:35 am Up
No milky residue on filler cap.
Why is it only now that you are telling me i may not need the head gasket doing when before when i posted before everyone said i do need it doing??
Im confused
crocdino
PostPosted: Tue Dec 27, 2011 8:40 am Up
I'd give Tech2 a bell in Rotherham..
Only about 30 miles away for you but Shaun there is properly on the ball with excellent rates!
GTI 138 facelift - Runabout
335d M Sport - Cruiser
greenpug2222
PostPosted: Wed Dec 28, 2011 4:16 pm Up
On the ball with what???
fatboyslim
PostPosted: Thu Dec 29, 2011 1:57 am Up
He means his charges are good,i.e 'his rates are on the ball' or 'his rates are spot on' etc
If there's no mayonaisse looking gunk on the filler cap or dipstick and no oil in the expansion tank then chances are your H/G is ok
I say chances as I had a H/G go once and it didn't show any of those symptoms as it hadn't broken through into an oil channel
Yes I own a CC and I'm neither gay or a hairdresser!!
greenpug2222
PostPosted: Thu Dec 29, 2011 3:21 am Up
Ok
I think the gasket has gone through into just the cooling gallery so that is why there is no oil mixing.
When i wrote up my symptoms before on here i was told by all that is was my head gasket and thats why i decided to call around for prices.
gixxerkev
PostPosted: Thu Dec 29, 2011 4:08 am Up
I dont think I read your symptoms but from what you're saying now I'd get the coolant system bled properly and replace the seal on the expansion tank cap first and then see if you're loosing any coolant before going for the head gasket. You could even try getting a compression test done on each cylinder, not sure if that would show anything though. A good indication (90% of the time) that the head gasket has gone/going is the milky mayo on the expansion tank cap and under the oil filler cap and under the rocker cover.
I remember having the sloshing sound in my footwell, so I drained the coolant and bled it properly and the sound went away.
Good luck.
An Ex '03 1.4 GLX driver, German technology all the way now.
greenpug2222
PostPosted: Wed Jan 04, 2012 1:58 pm Up
OK,
So the car is back from the garage....
My mechanic can not find anything wrong........... Hes done compression tests checked radiator and expansion tank and found nothing wrong.
He said it could be the water pump but didnt want waste my money if it wasnt that.
He also said the system is bleed properly as all hoses and ratiator etc were hot as needed.
I do have a new expansion cap on order so will try that.
Any other help is appriciated.
