Latest: SA01
Overall: 17138
Online Now [4170]:
Visitors: 4169
Today: 178752
Total: 111493081
Forums › The Car › 206 Problems › Pre plex part no.
Pre plex part no.
davieboy86
PostPosted: Tue Dec 27, 2011 6:57 am Up
Hi guys I was wondering of anyone knows the part number for a new non plexed radio stalk for the steering wheel( the long thin one). Just installed all the cabling to make it work with my Sony head unit and no joy.
All of the wires seemed to be plugged in correctly and only a tiny single wire connector block that I can't figure out where it goes ( or if it even plugs into anything at all) Is loose, so I assume it must be the stalk has stopped working.
Thanks for any help guys.
PostPosted: Tue Dec 27, 2011 7:54 am Up
6239 J4 (£38.88) REMOTE CONTROL - PERFORMANCE 2 RDS RADIO
6239 J5 (£29.29) REMOTE CONTROL - PERFORMANCE 1 RADIO
6239 K2 (£27.86) REMOTE CONTROL - "RD1" RDS COMPACT DISC AUDIO SYSTEM
PostPosted: Tue Dec 27, 2011 8:58 am Up
I've got one if you need one.
PostPosted: Tue Dec 27, 2011 9:55 am Up
Did it work with with the standard head unit? You sure you plugged it in the right way? I know i had fun with mine it was quite fussy with what order it went in.
davieboy86
PostPosted: Tue Dec 27, 2011 10:19 am Up
Yeah it worked fine with the original head unit, then I swapped for my Sony stereo about a year ago and I've finally got around to fitting the stalk kit. I assumed it was all plug and play so it should be working straight away. maybe I've broke the stalk in the ensuring year?
I undid the connections from the car to stereo, connected the car loom to the adaptor block, attached the patch lead for sony kit.
I'll try swapping some of the connections over although I'm sure they only fit to a particular part of the stalk kit I brought.
davieboy86
PostPosted: Tue Dec 27, 2011 10:21 am Up
Thanks lee ill try changing over some of the connections first just to see if it's anything else.
