Latest: ArtistKS
Overall: 17145
Online Now [62]:
Visitors: 61
Today: 15695
Total: 115915592
Forums › The Car › 206 Problems › 1.9 D clock
1.9 D clock
Jammie_1989
PostPosted: Tue Dec 27, 2011 2:09 pm Up
Hi Guys
The rev counter on my clocks doesnt work and the trip comupter is alot buggered. If I get new clocks will my milage stay the same?
206 gti 180
starkie
PostPosted: Tue Dec 27, 2011 2:10 pm Up
not if you get ones were mileage is higher.. only if it is less
Starkie =]
Jammie_1989
PostPosted: Tue Dec 27, 2011 2:12 pm Up
Thanks next question Laughing the clocks currently in there rev upto 7k but with it being a deisel redline should be around 5k if i buy the clocks with a 5k red line will they work as long as its the correct fitment?
Thanks for your rapid responce Smile
206 gti 180
Pre plex, the mileage is with the clocks
Multi plex, will update to a higher mileage if clocks if higher or just stay the same if lower
Jammie_1989
PostPosted: Tue Dec 27, 2011 2:13 pm Up
How do you know which one it which? Guessing as mine is only one plug it will be Pre plex Sad
206 gti 180
PostPosted: Tue Dec 27, 2011 2:21 pm Up
Only 1 plug on the back of the instrument cluster = MULTIPLEXED Wink
It will also have 2 reset knobs sticking out the front of the cluster.
Make sure the replacement cluster has a LOWER mileage on then the car currently has.
Jammie_1989
PostPosted: Tue Dec 27, 2011 2:24 pm Up
Thats great thanks so can I get one which has the correct red line as well?
206 gti 180
You read this You will have got it in your inbox when you joined but like most people, you probably ignored it
PostPosted: Tue Dec 27, 2011 2:25 pm Up
Should be able to.
Whats the VIN number, ill have a look on Service Box.
Jammie_1989
PostPosted: Sun Jan 01, 2012 2:31 pm Up
Should be able to.
Thanks VIN is VF32CWJYF42002358
206 gti 180
PostPosted: Sun Jan 01, 2012 2:38 pm Up
Should be able to.
Peugeot / Citroen part number 6106 LY Instrument cluster £307.88
Jammie_1989
PostPosted: Sun Jan 01, 2012 2:43 pm Up
Should be able to.
Found a single plug one on ebay with 84k miles on it for £35 Smile
206 gti 180
PostPosted: Sun Jan 01, 2012 2:45 pm Up
Jammie_1989 wrote:
Should be able to.
All of a 2 minute job to fit Wink
Unclip the surround, undo the 1 torx screw, lift up the cluster, unclip the connector, refitting is reversal of removal.
Enjoy the needle party trick when you turn the ignition on Laughing
Jammie_1989
PostPosted: Sun Jan 01, 2012 2:48 pm Up
MrBSI wrote:
Jammie_1989 wrote:
Should be able to.
Thanks for your help with this appreciated Smile now do you know what might be causing the knocking noised from the back end? Laughing
206 gti 180
Jammie_1989
PostPosted: Mon Jan 16, 2012 4:00 pm Up
Clock I found wasn't 84k was 184k when I asked about it Sad finding one on less than £97k seems impossible or when I ring up the muppets that break the cars don't know what day it is never mind the millage of anything.
206 gti 180
