Latest: Beduff1977
Overall: 17134
Online Now [661]:
Visitors: 660
Today: 142545
Total: 108478735
Forums › The Car › 206 Problems › Running issue
Running issue
quikie
PostPosted: Wed Dec 28, 2011 5:29 am Up
Hi, Im looking for some much needed help.
My woman has an `06 206 1.4
Its developed a random fault.
Now and again the EML light will come on and the car will run like a bag of snails.. the car does not stall but will idle quite roughly, it still drives but looses alot of power. The plugs and coil have been changed.
In your opinion would the ICV cause a problem like this? My thinking is it only "operates" below 1000rpm or so? Could a dirty ICV cause issues like this?
Has anyone else had a similar issue? I have checked throught the solved problem forum but had no luck.
Please advise, im cracking up lol
Cheers
Paul
PostPosted: Wed Dec 28, 2011 5:34 am Up
Scan it for fault codes is the first easy step.
You say the plugs have been changed, hope you didnt fit NGK ones Laughing
quikie
PostPosted: Wed Dec 28, 2011 5:43 am Up
No fault codes appeared, it's a sl*t!
Had a "mechanic" change the Plugs and do two days worth of testing which came to nothing.
Car came home and problem came back!
Are the plugs visible on removal of the coil as I can whip it off for a look.
E30
PostPosted: Wed Dec 28, 2011 5:48 am Up
What equpiment was it scanned with?
If it was a cheap generic scanner then it might not read manufacturers fault codes.
1.4 could be TU3 - 8 valve or ET3 - 16 valve.
Coil pack is easy enough to remove then just take a plug out & have a look.
quikie
PostPosted: Wed Dec 28, 2011 6:10 am Up
My mates solus, 5k worth of junk lol.
Where's the engine code stamped?
Can't believe I don't know the answer :-/
E30
PostPosted: Wed Dec 28, 2011 6:51 am Up
Engine fault codes will be stored in the engine ecu.
Peugeot Planet is the best thing to scan it with Wink
gixxerkev
PostPosted: Wed Dec 28, 2011 7:13 am Up
Talking of Peugeot Planet, where's the plug that the diagnostic cable plugs into. Is it in the car or under the bonnet?
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Wed Dec 28, 2011 7:19 am Up
It has to be inside the passenger compartment & within reach of the drivers seat by law Wink
The 16 pin diagnostic socket is behind the dash flap to the right of the drivers knee.
Use a coin to turn the plastic screw head then lift up / unclip the flap.
gixxerkev
PostPosted: Wed Dec 28, 2011 7:30 am Up
Thanks for gen Mr BSI, very helpful as usual. Is £30 for a cable and software CD a good deal form eBay as in this link -
www.ebay.co.uk/itm/300...1438.l2649
quikie
PostPosted: Wed Dec 28, 2011 7:46 am Up
Got my buddy on the case. Going to get it on the solus again and see if anything has reappeared.
Been out ragging it the Past hour and no issues ggrrrrr
Plugs are Bosch.
E30
Rob2859
PostPosted: Wed Dec 28, 2011 7:07 pm Up
[quote="MrBSI"]
Why is it by law?
