Latest: flipflap
Overall: 17140
Online Now [96]:
Visitors: 95
Today: 21407
Total: 113928679
Forums › The Car › 206 Problems › Fan
Fan
ryanovsalford
PostPosted: Fri Dec 30, 2011 10:51 am Up
Hi guys not a problem as such but how would i go about making the rad fan work off a switch in side
PostPosted: Fri Dec 30, 2011 11:12 am Up
ignition +12v > switch > fan > earth
ryanovsalford
PostPosted: Fri Dec 30, 2011 11:15 am Up
Cheers so if i unplug it and take the conector off there will b only to wires 1 + and 1-
PostPosted: Fri Dec 30, 2011 11:21 am Up
At the moment there will be a few wires around the fan as there are relays and a resistor for the fan speed, but you only need the two wires to make it work
PostPosted: Fri Dec 30, 2011 11:23 am Up
Why do you want to add a switch to make the fan work?
Whats wrong with the standard set up?
PostPosted: Fri Dec 30, 2011 12:48 pm Up
Standard set up is perfect if it is working.
ryanovsalford
PostPosted: Fri Dec 30, 2011 2:13 pm Up
Set up not working lol so got a spare switch might as well wire it up
PostPosted: Fri Dec 30, 2011 3:31 pm Up
If it's not working then fix it. Chance are it's a crusty relay or broken wiring to the terminals of the relay. Some cars have two coolant sensors, could be one of those faulty.
ryanovsalford
PostPosted: Fri Dec 30, 2011 3:56 pm Up
When i looks at the top of the engine there's two sensors a brown one and a green one could it b any of these because the temp guage has stopped working and there the only two that i can see go to the thermostat
PostPosted: Fri Dec 30, 2011 5:51 pm Up
Yes sounds like you might have found the problem. Which one does what I do not know though.
ryanovsalford
PostPosted: Fri Dec 30, 2011 6:28 pm Up
Now thats the big question might just go scrappy and grab on of each
