Online Now [224]:
Visitors: 223
Today: 17950
Total: 104945593
Forums › The Car › 206 Problems › ABS Warning Light
ABS Warning Light
richie079
PostPosted: Sun Jan 01, 2012 4:27 pm Up
Evening all,
Now i understand this is most likely a daft question or come up a 100 times but ive been offered a sweet deal to do a straight swap for my car for a 2002 206 GTI. Ive been told that the guy has recently changed a wheel bearing (not sure if its front or rear yet) and since then the ABS warning light has been showing on the dash. He says that its just because "he hasnt reset it or something" now im now a mechanic so i need some advice on this.
Are the wheel bearings like on some of my previous cars and come with the brake hubs attached? Or is changing a bearing even likely to set a warning light off?
I have to ask as i do i pretty much trust the guy ive dealt with him in the past and he didnt let me down but i dont want to get 20 miles down the road and find im in a duffer
Cheers for any help or advice you can give on this
PostPosted: Sun Jan 01, 2012 4:30 pm Up
More than likely the ABS ring has broken.
richie079
PostPosted: Sun Jan 01, 2012 4:32 pm Up
Please feel free to treat me like a fool here but ive no idea what an ABS ring would be or do, nor do i no if this is a serious and expensive fault? and should stop me getting the motor
206 wanna be superstar
Big_Rich180
PostPosted: Sun Jan 01, 2012 4:33 pm Up
changing the bearing wont cause a fault, also from experience when the ABS issue is resolved the light goes out on its own (no need to re-set the ecu ect).
As said its most likely the abs ring or sensor.
EDIT: The ABS ring is a gear shaped ring, the ABS sensor reads the bumps on the ring, if it is cracked the ABS sensor cant count the bumps.
They are on the front drive shaft or IIRC behind the rear wheel bearing, some garages will try to mack you buy the full drive shaft but i think you can get the rings on there own.....but its weather a garage will want to fit it on its own.
richie079
PostPosted: Sun Jan 01, 2012 4:36 pm Up
also while im on a roll of losing man points showing how little i know about cars....
Does the ABS work like the SRS system? In which i mean when the SRS light is showing on the dash it stops the system from working/firing the air bags? So would the ABS be "off" for want of a better word
Big_Rich180
PostPosted: Sun Jan 01, 2012 4:38 pm Up
Yes, the ABS will be off if there is a warning on the dash.
Just remembered that on the front the ABS ring comes with the CV joint..which is a cheaper option to a drive shaft.
richie079
PostPosted: Sun Jan 01, 2012 4:39 pm Up
Last one i swear..
Should this turn me off getting the motor or should i consider it a safe bet and a cheap repair?
Thanks for all the help here on my silly questions, it is very much appriciated
Big_Rich180
PostPosted: Sun Jan 01, 2012 4:42 pm Up
It could cost £150 to repair (probably on over estimate)
Just make sure all the other ABS rings are fine, check the rear axle for play and all the other usual car things.
Why does he want to swap his car for yours?
richie079
PostPosted: Sun Jan 01, 2012 4:44 pm Up
I haven't got that out of him yet. it just so happens i brought his old car off him 2 years ago and by the magic of swaps website he found it and wants it back.
Big_Rich180
PostPosted: Sun Jan 01, 2012 4:46 pm Up
Just make sure it isnt a dog, these cars can cost alot of money if they are not looked after.
richie079
PostPosted: Sun Jan 01, 2012 4:47 pm Up
Like i say i have his old motor and that's done me fine no really expensive repairs so i have some.faith in him but a brake problem leaves me a little.nervous as its fairly essential
Big_Rich180
PostPosted: Sun Jan 01, 2012 4:50 pm Up
I drove around in my 180 for nearly a year with no ABS, I think as long as you dont act like a d**k you wont end up backwards in a hedge lol
You will need it sorted for the MOT though.
richie079
PostPosted: Sun Jan 01, 2012 4:52 pm Up
Its got Mot until October so its safe for a while and my boy racer years are well behind me. thank you for your help.
