Online Now [137]:
Visitors: 136
Today: 105068
Total: 143303176
Forums › The Car › 206 Talk › 138 inlet manifold on 1.4 8v, possible?
TheGTIlad
PostPosted: Thu Jan 05, 2012 4:32 pm Up
Hi there all.
Some person i know owns a 206 and think's that it is possible to swap a gti 138 manifold on to his 1.4 8v TU lump. I'm 90% certain it is not possible and i just want to prove the arrogant d**che wrong. So is it possible to swap a 138 manifold to a 1.4 8v TU?
PostPosted: Thu Jan 05, 2012 4:33 pm Up
Rolling On The Floor Laughing no really not possibly
Unless you want to do a lot of fabrication that will prove absolutely pointless
PostPosted: Thu Jan 05, 2012 4:34 pm Up
No, not without substainial modification
Plus the benefits would be outweighed by the losses/effort
Andrew
PostPosted: Thu Jan 05, 2012 4:35 pm Up
I don't think its possible. For a start the inlet manifold is at the front of the GTi engine, on the TUs they are behind the engine, and I would be almost certain that the spacing and port sizes would not match.
Depending on the port spacing (00-00 or 0-0-0-0) and year, inlet manifolds from bigger TU engines should fit so long as the throttle body is the same mechanism as the original one - electric or cable
My 206 thread
www.detailedbyandrew.com
No, completly different designs.
TheGTIlad
PostPosted: Thu Jan 05, 2012 4:36 pm Up
HAHA!
Thank you very much! Smile
=ZiAn=
PostPosted: Thu Jan 05, 2012 5:37 pm Up
There are three possibilities:
1. if you put the GTI intake on the exhaust side of 1.4
2. if you put the GTI exhaust one on the intake of 1.4
3. flip the engine Laughing
ZianDesigns - Website designs
Rob2859
PostPosted: Thu Jan 05, 2012 7:25 pm Up
Anything is possible with the brains,time and the money, but it doesn't mean it will go faster at the end of it.
PostPosted: Thu Jan 05, 2012 9:58 pm Up
Gaffa tape the 138 manifold to the top of the tu lump? Very Happy
HDI90
PostPosted: Fri Jan 06, 2012 3:42 am Up
TB may be possible to put on but you wouldnt gain anything
GTI 180
PostPosted: Fri Jan 06, 2012 7:16 am Up
The EW engine will also be wider and the port spacing will be different. There's no reason for the design not to fit but the actual EW10 inlet won't fit.
PostPosted: Fri Jan 06, 2012 7:18 am Up
Let them get on with it then, we could do with a laugh on here Laughing
