Online Now [525]:
Visitors: 524
Today: 13146
Total: 106207377
Forums › The Car › 206 Problems › can you clean the dpf if it gets blocked?
vauxfan
PostPosted: Thu Jan 05, 2012 11:37 am Up
If you get a anti pollution fault can you clean the dpf some how?
pug all the way
PostPosted: Thu Jan 05, 2012 11:44 am Up
Got it already? Laughing
Needs the faults reading to see which part is faulty
PostPosted: Thu Jan 05, 2012 11:46 am Up
Rolling On The Floor Laughing that didnt take long Razz
PostPosted: Thu Jan 05, 2012 11:50 am Up
It may not even be the dpf "Anti-Pollution" comes up for a few faults
vauxfan
it came on once straight after the roof tile hit the roof and set the alarm off! we havn't even used the car, started wice after that to move it and it wasn't on then.
pug all the way
vauxfan
PostPosted: Thu Jan 05, 2012 12:31 pm Up
i have read some where that you can take the dpf off and jet wash it out?
pug all the way
PostPosted: Thu Jan 05, 2012 12:32 pm Up
Get it code read.
vauxfan
PostPosted: Fri Jan 06, 2012 2:29 pm Up
like this www.youtube.com/watch?v=nbFB5DWd9Sg
pug all the way
HDI90
PostPosted: Fri Jan 06, 2012 2:48 pm Up
Even if you did "wash" it out you would still need it remapping out as the fault will still be there
I think lee can tweek your ecu/bsi to remove it from the settings
GTI 180
vauxfan
PostPosted: Sat Jan 07, 2012 2:47 am Up
What if you smashed the honeycome out of it then mappep it! would that work?
pug all the way
Lecktorious
PostPosted: Sat Jan 07, 2012 2:54 am Up
Trade Rating: +59
What? Laughing
You don't map the fault out. Clean the DPF and re-set the pressure sensors to zero. If you have managed to clean it out enough, you might be able to force a regeneration with PP, or by taking it out a spin.
'98 Nile Blue 306 GTi 6
vauxfan
PostPosted: Sat Jan 07, 2012 3:19 am Up
whats pp mate? i have just read on the bmw site that from this year on if you don't have the dpf pipe in place you WILL fail the mot! the only way to foll them is to leave the pipe in place as an empty can! and map out of it.
pug all the way
PostPosted: Sat Jan 07, 2012 4:48 am Up
vauxfan wrote:
whats pp mate?
Peugeot Planet.
vauxfan
PostPosted: Sat Jan 07, 2012 9:45 am Up
is it just a diagnostic scanner? my mate has a snap on code reader,, wil that work? i should clean out the can then plug the diagnostic in to see where any faults are? had any 1 taken a can off before? is it just a peice off the center of the exhaust or is there some thing else attached to it?
pug all the way
PostPosted: Sat Jan 07, 2012 9:58 am Up
No, its software run from a computer.
