Posted: Thu Jan 05, 2012 3:08 pm |
Gonna keep this short and avoid a rant...
Just got in car and noticed the rev counter is stuck on 0.
Not sure whether it was fine when i pulled off then dropped as i was driving.
All other dials are working fine as far as i can see and car is driving and running fine.
Is this common? any suggestions?
Posted: Thu Jan 05, 2012 3:11 pm |
The same thing happend to me but the actual speedo dial. Isit still dead or does it move a bit or isit inaccurate
Posted: Thu Jan 05, 2012 3:12 pm |
completely stuck on 0 will not move...
Posted: Thu Jan 05, 2012 3:13 pm |
Have you checked all the fuses? My old car did that and it was a fuse.
Pull the cluster apart and check its on properly/not stuck?
Posted: Thu Jan 05, 2012 3:14 pm |
lukesaunders91 wrote: |
Have you checked all the fuses? My old car did that and it was a fuse. |
fuses under the bonnet or under the steering wheel?
Posted: Thu Jan 05, 2012 3:15 pm |
Your cars different, so its s**t im gathering
So i cant help, scrap yard?
| Team Impossible Possible
Addaz wrote: |
So i cant help, scrap yard? |
adam, **** off
Posted: Thu Jan 05, 2012 3:16 pm |
JordGJ wrote: |
Addaz wrote: |
adam, **** off |
To the scrap yard with your car?
Fo sure
Posted: Thu Jan 05, 2012 3:17 pm |
Read the live data, if it's detecting the revs then the cluster is f****d
If not the sensor is knackered
Posted: Thu Jan 05, 2012 3:19 pm |
I know it's not Peugeot but my mates berlingo did the same (1998). took batt off for 10mins and it was fine after that, just an idea.
Posted: Thu Jan 05, 2012 3:20 pm |
Saxo has always done it, diagnoses equipment doesn't work with it so I checked all the fuses, replaced the cluster and it is still doing it.
Haven't got round to trying anything else yet
Lee wrote: |
If not the sensor is knackered |
i'm simple when it comes to anything technical with cars as you well know... can you explain what you mean in idiot speak please
Posted: Thu Jan 05, 2012 3:22 pm |
Plug the laptop in to see if it's reading the RPM
JordGJ wrote: |
Lee wrote: |
i'm simple when it comes to anything technical with cars as you well know... can you explain what you mean in idiot speak please |
Scrap.
Yard.
Better?
