Latest: Kifi69
Overall: 17183
Online Now [512]:
Visitors: 511
Today: 55304
Total: 143604020
Forums › The Car › 206 Problems › 206 HDI cutting out, fail's to restart
Spiky
PostPosted: Sun Jan 08, 2012 11:53 am Up
i have a 2000 x 206 HDI, that was fine for 7 months, then one day stalled while i was driving.
tried to restart it, it wouldnt, left it an hour or so and it started and run fine, one left it over night and it was fine.
it has done this about 5 times now,
when it wont start you cant hear the fuel pump priming, or the fuel relay click
any ideas?
is there a way to bridge the connections on the fuel pump relay to eliminate that?
HDI90
PostPosted: Sun Jan 08, 2012 11:59 am Up
the fuel pump is on the engine driven by a belt so you cannot bridge that!
Have you got any warning lights showing up?
GTI 180
Spiky
PostPosted: Sun Jan 08, 2012 12:01 pm Up
i want to bridge the fuel pump relay, not the actual pump, incase that is broke
no warning lights at all
206 HDI Dturbo X/2000
andygriff
PostPosted: Sun Jan 08, 2012 12:08 pm Up
i have got the same problem on my gti justs cuts out no fuel comein up leave it for a hour then it starts fine again, i was thinkin faulty fuel relay that is under the ecu
206gti
HDI90
PostPosted: Sun Jan 08, 2012 1:39 pm Up
Have a look what other working relays are in there and switch them over
GTI 180
Spiky
PostPosted: Sun Jan 08, 2012 2:16 pm Up
The fuel relay is like no other on the car
PostPosted: Sun Jan 08, 2012 2:24 pm Up
Eh? Since when? So what is that sound when you turn on the ignition...
Ash
PostPosted: Sun Jan 08, 2012 2:27 pm Up
That's the engine idling therefore priming the fuel.
And then you turn it again and the engine starts.
PostPosted: Sun Jan 08, 2012 2:31 pm Up
I always thought it was electric...
PostPosted: Sun Jan 08, 2012 2:35 pm Up
Electric lift pump in the tank & mechanical high pressure pump on the engine.
the HP pump is belt driven
PostPosted: Sun Jan 08, 2012 2:43 pm Up
So I was half right... Ah well, you learn something new everyday.
PostPosted: Sun Jan 08, 2012 3:00 pm Up
Depends on the HDI engine in question & what it's fitted to.
Some HDI set up's dont have / need the electric in tank lift pump.
Spiky
PostPosted: Sun Jan 08, 2012 5:41 pm Up
mine has a lift pump in tank,
and that done sound nor does rhe relat under the ECU click, when it wont start
so i dont know if the relay is knackered or wiring fault, or maybe ECU
or something else i dont know about?
Spiky
PostPosted: Sun Jan 08, 2012 5:43 pm Up
idling..lol nope, thats the fuel system being primed Very Happy
