Online Now [51]:
Visitors: 50
Today: 53075
Total: 106182716
Forums › The Car › 206 Problems › 206 gti Air Con problems
adriansoul
PostPosted: Mon Jan 09, 2012 12:18 am Up
Hi there,
I just brought a used Peugeot 206 Gti 2.0 Yr 2000, but I found the air con is not working. I found a cracked condenser in the system and I am going to replace it, but someone recommended me to replace the receiver drier also once I open up the system. But I can't find any drier receiver, I did some research on the internet, looks like a receiver drier in a Peugeot 206 should be located between the pipe from the lower condenser to the pressure switch, but in my Peugeot 206 Gti, it looks like someone took off the receiver drier, bended the pipe from the pressure switch and connected to the condenser.
What should the piping in the air con looks like??
Are all 206 model have the same air con system?Where can I find a receiver drier in a 206 gti??
hope someone could help, thanks a lot
PostPosted: Mon Jan 09, 2012 6:16 am Up
Should look like this...
adriansoul
PostPosted: Tue Jan 10, 2012 5:52 pm Up
So I'm sure someone have taken it off now!Thanks
