Posted: Sat Jan 14, 2012 10:52 am |
Basically was fitting my new brakelight today and think I may have over tightened the nut on 1 of the bolts because as I heard a slight creak noise and noticed the light sits slightly off the norm
Posted: Sat Jan 14, 2012 10:59 am |
super glue it?
Posted: Sat Jan 14, 2012 11:03 am |
im hoping i haven't broke the plastic which holds the bolts in, arrodite should do the trick though if I have or i'll just buy a new 1
Posted: Sat Jan 14, 2012 1:11 pm |
| MattyP wrote: |
| arrodite should do the trick |
It won't
Posted: Sat Jan 14, 2012 1:42 pm |
had a look and it's not broken, just a design fault with the brakelight where it doesn't sit flush but even worse, it now does not work and think the wire has got caught when tightening it
Posted: Sat Jan 14, 2012 1:47 pm |
Will be a simple 30second fix.
Posted: Sat Jan 14, 2012 2:13 pm |
what's best to connect the wires together bearing in mind there is limited space behind the light
Posted: Sat Jan 14, 2012 3:14 pm |
| MattyP wrote: |
| what's best to connect the wires together bearing in mind there is limited space behind the light |
Best - I'd say solder and shrink tubing...
I went with crimp connectors (inline tube style) and that's been fine for 7 years now...
| Silvermetallic 2004 206 RC | |
