Online Now [643]:
Visitors: 642
Today: 19029
Total: 146917598
Forums › The Car › 206 Problems › 206 GTI REAR BRAKE RENEWAL
Linkpad
PostPosted: Wed Jan 11, 2012 7:51 am Up
Hi i have a 2000 206 GTI and want to renew the rear Disks & Pads i have seen all the guides for front brakes but none for the rear do you need to wind the piston back ?
Also i found on my front that the 13mm bolts will not shift for anything is there anything that will take those buggers out without rounding them off !! Shocked
Boo
PostPosted: Wed Jan 11, 2012 7:56 am Up
Never had a problem removing the 13mm bolts from the front. You using a socket or an open ended spanner?
Rear calipers need the pistons rewinding.
Linkpad
PostPosted: Wed Jan 11, 2012 7:59 am Up
What tool you need for the winding ? And as for the 13mm Bolts i used a hand Torque Wrench and that woudn't even move them. Ive also tried a high impact spanner (open ended) none of which have moved but infact started to round it off slightly, ive sprayed it bashed it, cursed it, shown it pictures of Justin Bieber and the bolt still won't shift
Boo
Lecktorious
PostPosted: Wed Jan 11, 2012 8:14 am Up
Trade Rating: +59
Use a breaker bar.
'98 Nile Blue 306 GTi 6
Why not just get new callipers... Actually, I have a pair for sale lol, 3k old.
Wink
crocdino
PostPosted: Wed Jan 11, 2012 10:29 am Up
I had to use a breaker bar for the bolts.
GTI 138 facelift - Runabout
335d M Sport - Cruiser
Linkpad
PostPosted: Thu Jan 12, 2012 5:07 am Up
OK thanks ill try that, its just getting access to the bolts is a pain too as there on the inside in such an ackward position to get any leverage on them <Sigh French Engineering>
Boo
