Posted: Tue Jan 17, 2012 11:16 am |
i have a 206 1.6 16v glx its covered 90,000 miles how much should i be asking for the engine ?
| | ![](images/spacer.gif) |
Posted: Tue Jan 17, 2012 11:26 am |
why the engine?? :S
Posted: Tue Jan 17, 2012 11:36 am |
about £170 if your lucky. The mileage will put people off.
Posted: Tue Jan 17, 2012 12:41 pm |
Around £150 maybe.
| PM me for Valeting & Detailing services at great rates!
Detailing Guides are also available ask me for more information. | |
Posted: Tue Jan 17, 2012 12:48 pm |
Should still be perfectly healthy at that age especially if it's been serviced regularly.
Posted: Tue Jan 17, 2012 4:15 pm |
Ask what you want (most people here do), but I reckon you'll get between £0 & £50.
