Latest: ArtistKS
Overall: 17145
Online Now [94]:
Visitors: 93
Today: 22470
Total: 116115631
Forums › The Car › 206 Problems › STOP limp mode???
STOP limp mode???
scottishdave
PostPosted: Wed Jan 18, 2012 2:48 pm Up
Hi
The missus had got a 206 with a crappy al4 gearbox, it keeps flashing the ice and sports buttons and goes into limp mode.
Now I'm going to get her a new gearbox off the warranty but is there anyway I can stop the car going into limp mode?
Or stop it from flashing the sport and snow button as it very annoying.
I know it needs fixing but I will get around to it eventually, I know you can restart the car and restarts the sensors but is there any other solutions?
PostPosted: Wed Jan 18, 2012 2:57 pm Up
Not until you fix the gearbox. The ECU is trying to prevent things getting worse. Is it a Peugeot warranty?
scottishdave
PostPosted: Wed Jan 18, 2012 3:02 pm Up
Cheers mate.
No its aftersales warranty mate when my missus bought the car.
PostPosted: Wed Jan 18, 2012 3:06 pm Up
Quote::
The (AL4) autoadaptive automatic gearbox is lubricated for life .
All that is required is an oil level check at 60000 km .
Despite that, the automatic gearbox has a system for measuring oil quality .
The AL4 autoadaptive automatic gearbox ECU has an oil wear sensor .
For a given time interval, the counter increases by a certain number of units (of wear) depending on the temperature of the gearbox .
When the counter is exhausted, the gearbox ECU informs the driver of the presence of a fault by the flashing of the Sport and Snow indicator lights on the instrument panel .
Using the diagnostic equipment, the technician checks whether or not it is necessary to replace the gearbox oil .
scottishdave
PostPosted: Wed Jan 18, 2012 3:41 pm Up
Thanks for that but thats not the only reason why the ice and snow buttons flash.
PostPosted: Wed Jan 18, 2012 4:54 pm Up
What mileage is yours at. I would say it wouldnt do any harm chaging gearbox oil anyway.
scottishdave
PostPosted: Wed Jan 18, 2012 5:26 pm Up
Its 68,000 miles, changed it but still flashes mate.
deanparkr
PostPosted: Wed Jan 18, 2012 5:52 pm Up
Same gearbox, same mileage here Smile
I dont think you'll be able to stop it from going into Limp mode. You'll need to get the codes read first to find out what the cause is.
2002 1.4LX
