Posted: Fri Dec 23, 2011 10:16 am |
Hi Guys.
So, I drove back home from work a few days ago and noticed that my Speedo meter wasn't working. My dad drove the car to work, he said it went up to 30mph then dropped back down. I have drove my car since then the needle just doesn't work the mileage goes up, the rpm is working.
Any ideas on how to fix the speedo?
Vandana
Posted: Fri Dec 23, 2011 10:41 am |
Faulty cluster probably.
Could try a BSI reset as that is free and quick, but I don't think it will do anything.
Posted: Fri Dec 23, 2011 11:11 am |
Thanks I'll try that out, finger crossed it will work =)
Posted: Fri Dec 23, 2011 11:15 am |
Posted: Fri Dec 23, 2011 11:23 am |
Oh ok thanks, my 206 is pretty old its 1999 1.1 petrol do you think it might be still compatible?
Posted: Fri Dec 23, 2011 11:48 am |
Mine did this. Was a broken wire behind the front bumper.
Posted: Wed Jan 18, 2012 2:29 am |
IS this repaired now?
If so how much did it cost? my speedo is faulty it keeps jamming up, everything else works fine its jus the speedo.
| Pug 206 1.4 SW - July 2013 - Present
Peugeot 206 1.4 HDI - Oct 2013 - Present
BMW E30 - April 2013 - RIP | |
