Online Now [500]:
Visitors: 500
Today: 27510
Total: 142739873
Forums › The Car › 206 Problems › Firing up
Firing up
stedmeister
PostPosted: Wed Jan 18, 2012 3:07 pm Up
My 2005 has sometimes started to take a long time firing up. I've been told it could be the battery is going (it's still the original battery so could be on is last legs).
Before I splash out on a battery test does anyone know if this could be something else (I'm not mechanically minded and wondered if it might be the starter motor)
Any help appreciated.
Stedmeister
is it petrol or diesel ?
when was it last serviced?
PostPosted: Wed Jan 18, 2012 3:08 pm Up
More info on what the engine is might help...
stedmeister
PostPosted: Wed Jan 18, 2012 3:10 pm Up
It's a 1.4 petrol. LAst serviced April 2011. I don't do many miles so it's not due another until this April
Stedmeister
Stemh
PostPosted: Wed Jan 18, 2012 7:04 pm Up
Most places will do a free battery/alternator check. Most likely isnt the starter motor because it wouldn't turn over at all if that had gone/jammed.
gazza82
PostPosted: Thu Jan 19, 2012 5:49 am Up
6 years is pushing a battery to the max ... especially if it isn't driven much (lots of stop-start?)
PostPosted: Thu Jan 19, 2012 7:14 am Up
What He Said plus during winter almost everywhere you go you have your lights, heater blower, rear demister, wipers turned on, so on short journeys the alternator can't produce enough power to replenish that used from the battery
stedmeister
PostPosted: Thu Jan 19, 2012 8:54 am Up
Thanks all. Will take it for battery check
Stedmeister
