Online Now [76]:
Visitors: 75
Today: 16243
Total: 104925821
Forums › The Car › 206 Problems › window water jets
window water jets
amills58
PostPosted: Tue Jan 17, 2012 10:30 am Up
My water jets are not working, I can hear them working but no water comes out, I have tried sticking a needle down the bit where the water comes out to see if they were just blocked, but still nothing comes out.
They are full, (before someone asks) and I have tried following the lead but I cant actually see where it goes into the filler tank.
Could someone please help.....
Adam
Adam Miller
Abzynthe
PostPosted: Tue Jan 17, 2012 10:31 am Up
East Area Rep - Abzynthe
It might be frozen somewhere. Mine were blocked yesterday, but I sprayed some pre icer on the jets last night and they worked this morning Smile
amills58
PostPosted: Tue Jan 17, 2012 10:34 am Up
I travelled about a 45 min journey, then left them till the afternoon still not working, the odd thing is as well that I forgot to mention, is, there is water that kind of tricles out and bubbles a little bit, from where the water comes out.
Adam Miller
PostPosted: Tue Jan 17, 2012 10:35 am Up
What He Said
If the screen wash isnt mixed correctly the washers jets will freeze up.
Mine worked fine at -5 this morning Laughing
Gems
PostPosted: Tue Jan 17, 2012 10:57 am Up
South East Area Rep - Gems
has the pipe popped off the back? That happened to mine recently...
Ash
PostPosted: Tue Jan 17, 2012 11:02 am Up
Undo them, blow some compressed air through them (going from the outlet to the inlet) and retry.
Alternatively, soak them for a bit in water, run some water through and give them a general good clean.
The air way worked perfectly for me though.
Or as above, you may have ice in which case, get some proper screenwash in the correct concentration for winter usage.
gixxerkev
PostPosted: Tue Jan 17, 2012 11:07 am Up
When was the last time they worked?
An Ex '03 1.4 GLX driver, German technology all the way now.
amills58
PostPosted: Tue Jan 17, 2012 11:14 am Up
How do you find the pipe that goes into the filler tank?
They worked about a week ago I think
Also how do you undo them??
Adam Miller
