Latest: Kifi69
Overall: 17183
Online Now [438]:
Visitors: 437
Today: 6212
Total: 144826883
Forums › The Car › 206 Problems › Water leak problem.
Water leak problem.
Necro
PostPosted: Tue Jan 17, 2012 3:07 pm Up
Got water leaking from where the arrow is pointing.
How do I take this box apart so I can investigate further?
It seems like its a few clips holding it together but when I pull on the clips, the box won't budge.
Help!
PostPosted: Tue Jan 17, 2012 3:10 pm Up
Looks like your buying a new heater matrix.
nellyhaggis
PostPosted: Tue Jan 17, 2012 3:38 pm Up
stick some rad seal in your car.
If it works its a cheap fix!
Did on mine!
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Necro
PostPosted: Tue Jan 17, 2012 3:48 pm Up
Radseal worked for you when it was leaking from where mine is?
Pug 206 GTi 138 Owner.
PostPosted: Tue Jan 17, 2012 3:55 pm Up
Might help, thats where your water runs from your engine to heat your car.
Necro
PostPosted: Tue Jan 17, 2012 4:09 pm Up
Any ideas how to take it apart though?
PostPosted: Tue Jan 17, 2012 4:33 pm Up
Think it needs to be taken out whole and swapped.
Necro
PostPosted: Tue Jan 17, 2012 4:35 pm Up
Sad
phillspug
PostPosted: Tue Jan 17, 2012 5:30 pm Up
K seal is better than rad seal Wink
Necro
PostPosted: Wed Jan 18, 2012 7:18 am Up
Any other ideas ppls?
Deckchair5
PostPosted: Wed Jan 18, 2012 7:29 am Up
Have a look and see if it's an o ring on the supply or return pipes causing the leak.
If not then you'll need to drain the system down and disconnect the pipes in order to remove the matrix
Necro
PostPosted: Thu Jan 19, 2012 7:33 am Up
Any ideas on how to unlock the clips holding the twin pipes and the black box together?
I've just been out trying to unclip the thing but nothings working.
PostPosted: Thu Jan 19, 2012 10:47 am Up
you pull the clips up and pull the matrix out like this......
so if it leaking from behind that plate it will need new matrix i would say,
if its comming from bottom of the two pipes were they join, might just need new rubbers on joints, in the joint pictured here......
Necro
PostPosted: Thu Jan 19, 2012 11:29 am Up
Got it off. Broke the clips though Sad
Need a new matrix, got a few holes in it Sad
PostPosted: Thu Jan 19, 2012 11:31 am Up
I have the one above for sale, its untested tho but looks in good condition.
