Latest: tc.206
Overall: 17147
Online Now [54]:
Visitors: 53
Today: 13494
Total: 116297889
Forums › The Car › 206 Problems › Eml light - anti pollution *updated!!
Danw_VVT
PostPosted: Tue Jan 17, 2012 5:38 pm Up
I have a 421 manifold with hi flow cat and straight through centre. I recently got the cat fitted and post cat sensor extended so it was then post cat. Had the fault codes wiped and the light went. Brill.
Just reset the service indicator and the eml has popped back On is this because the cat is a hi flow?
PostPosted: Tue Jan 17, 2012 5:41 pm Up
I'd have the codes re-read mate. What was the code last time?
Danw_VVT
PostPosted: Tue Jan 17, 2012 5:45 pm Up
Couple of cat converter system fairs and o2 sensor faults
PostPosted: Tue Jan 17, 2012 5:47 pm Up
Definately get it code read, seen it a few times for completely different things could be a coincident
which O2 sensor?
either way you need to fix the sensor first or the cat will died very soon
Danw_VVT
PostPosted: Tue Jan 17, 2012 5:53 pm Up
Dunno what one will check tomorrow
Big_Rich180
PostPosted: Wed Jan 18, 2012 4:22 am Up
Isnt your's a VVT engine?
It threw the same fault up on my 180 when the VVT sensor was shot.
But yeah, best to get the codes read.
Danw_VVT
PostPosted: Wed Jan 18, 2012 4:25 am Up
Yeah it's vvt gonna get it read again tonight will let u no
Danw_VVT
PostPosted: Sat Feb 11, 2012 3:13 pm Up
Ok so a lil update I recently replaced the post cat sensor with a new one and heat wrapped it as I know thaws can work badly if they don't heat enOugh cleared the codes and all was well.
However the eml light is back on again same o2 sensor number 2 fault.
Any ideas?
PostPosted: Sat Feb 11, 2012 3:25 pm Up
Genuine part or cheap motorfactor crap?
Danw_VVT
PostPosted: Sat Feb 11, 2012 3:26 pm Up
Previous one in there was a fpl or something I replaced it with a ngk
PostPosted: Sat Feb 11, 2012 4:15 pm Up
get the bosch O2 sensor
