Latest: tbafonso
Overall: 17130
Online Now [388]:
Visitors: 388
Today: 12751
Total: 102485023
Forums › The Car › 206 Problems › Accelerating, High revs low power
Yoshii
PostPosted: Thu Feb 09, 2012 3:33 pm Up
Hello everyone, i have hit my first problem on my 206!
Just recently i went for a drive and the car didnt feel right, put it into 2nd gear and put my foot down but the car just wont move like before :/.
Never happend before! The rev meter is on 4 or 5 but the car just goes up in speed slowly, dont feel powerful no more :(.
One of my friends said it was a problem with the clutch and i think so too, your views will be welcome.
Also when i start up my car and its in neutral, the rev meter aint on 0 its half way between 0 & 1, quiet odd.
My car is 1.4 sport 16v 2005 Smile
206 Hype !
Matt
PostPosted: Thu Feb 09, 2012 3:46 pm Up
Trade Rating: +32
When the car is running it will never be on 0. O a cold day it should be just under 1k.
Other proble could be a few different things. When was the car last serviced?
Yoshii
PostPosted: Thu Feb 09, 2012 3:48 pm Up
Oh ok, ummm about a year ago
206 Hype !
Martind
PostPosted: Thu Feb 09, 2012 3:49 pm Up
When your car is on idle it should be reving between 500-1000 revs.
Is the clutch slipping?
Matt
PostPosted: Thu Feb 09, 2012 3:52 pm Up
Trade Rating: +32
A year ago , how many miles since last service?
Yoshii
PostPosted: Thu Feb 09, 2012 3:58 pm Up
i think 10 - 12,000
Yh Martin thats what 1 of my mates said but aint too sure :/
206 Hype !
Yoshii
Im dur for an MOT at the end of this month aswell
206 Hype !
Martind
PostPosted: Thu Feb 09, 2012 4:09 pm Up
When you are driving and it revs high, when you ease off the gas, does it (hard to explain) sort of jolt/catch (like an automatic changing gear) and if you put too much power down in too high a gear, does it just rev?
When you have been letting the car do this for a while, does it smell bad? Sort of cabbagey?
To see if your clutch is slipping, go out and start it. Leave the handbrake on, stick it in 4th.
Slowy start lifting the clutch.... When it gets to biting point, does the back of the car dip and revs drop like it will stall if you release clutch?
Or does it slip?
Matt
PostPosted: Thu Feb 09, 2012 4:19 pm Up
Trade Rating: +32
Best bet is get it serviced and see how it is after that.
Yoshii
When i put too much power it will jus rev for about 10 seconds then i ease off a bit then i start picking up speed, hard to explain :/
Ok i will try it 2moro morning and will let you know mate.
206 Hype !
Matt
PostPosted: Thu Feb 09, 2012 4:22 pm Up
Trade Rating: +32
Could be coil pack or injectors...
I have a similar problem. I'm just in the process of getting a new coil pack to see if that helps it at all.
Yoshii
Hmm my best bet is to probably get it serviced yh ...
206 Hype !
Matt
PostPosted: Thu Feb 09, 2012 4:25 pm Up
Trade Rating: +32
I would say so yea.
Martind
PostPosted: Thu Feb 09, 2012 4:28 pm Up
Let me know how you get on checking the clutch, because what you have just said sounds like the clutch is slipping.
Might as well check it, seeing as that is free to do. It would be silly to spend money on parts when you haven't ruled that out.
Get a local mechanic to take it round the block, more than likely do it for free if it is a small 1man band type garage.
Yoshii
PostPosted: Thu Feb 09, 2012 4:31 pm Up
Thanks alot Martin will update you 2morow Smile
206 Hype !
