Posted: Thu Jan 19, 2012 12:39 pm |
I've always wondered why there is about 10hp difference between the Silvertop Saxo VTR (98hp) and the 206 XS (88hp) when it is the same 1.6 8 valve engine. What exactly makes the difference?
- Cam
- Head
- ECU Map
Posted: Thu Jan 19, 2012 1:08 pm |
bear in mind that early silvertop can also be 90bhp
anyway they are totally different....
latest VTR has higher compression (via different piston)
Black top run solid lifter while silver top use hydraulic (so cam is different too)
inlet+throttle body are different
ECU are different 1 plug vs 3 plug
just to confused you more
106 S2 rallye also has a 1.6 8v engine but has 103bhp
Posted: Thu Jan 19, 2012 1:16 pm |
Seabook wrote: |
106 S2 rallye also has a 1.6 8v engine but has 103bhp  |
ECU modification
Posted: Thu Jan 19, 2012 1:21 pm |
macj wrote: |
Seabook wrote: |
ECU modification |
tbh i prefer S1 more
Posted: Thu Jan 19, 2012 3:10 pm |
mines 1.6 8v xs so would a re map make much diffrence ?
| peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim | |
Posted: Thu Jan 19, 2012 3:22 pm |
Dont forget the 106 Xsi engine which has 103
| Team Impossible Possible
Posted: Thu Jan 19, 2012 3:27 pm |
Thanks for the replies so far
Solid lifters can rev higher so I understand the difference, but what did they do to make the late silver top just that bit better than the 206 xs? My guess is the cam
Posted: Thu Jan 19, 2012 3:37 pm |
Addaz wrote: |
Dont forget the 106 Xsi engine which has 103  |
the XSI is 16valve no?
Posted: Thu Jan 19, 2012 3:41 pm |
Andrewxps wrote: |
Solid lifters can rev higher so I understand the difference, but what did they do to make the late silver top just that bit better than the 206 xs? My guess is the cam |
cam, throttle body and piston....
like i have said in the first post....
Posted: Thu Jan 19, 2012 4:05 pm |
ramigojag wrote: |
Addaz wrote: |
the XSI is 16valve no? |
206 yes, 106 no
Posted: Thu Jan 19, 2012 5:06 pm |
Seabook wrote: |
Andrewxps wrote: |
like i have said in the first post.... |
Its not that I ignored your first post, I just thought that you were referring to the black top engine
Thanks for clearing it up
Cheers for the replies everyone
Posted: Thu Jan 19, 2012 7:44 pm |
I have a question, why did Peugeot not put the better engine in the 206?
Posted: Sat Jan 21, 2012 12:01 pm |
Rob2859 wrote: |
I have a question, why did Peugeot not put the better engine in the 206?  |
They phased out the 8v in the 206 by 2002 to make way for the 16v which was also detuned compared to the one in the 106/Saxo - I am guessing this could have been to help sell the last 106s/Saxos, or maybe they wanted to keep the power low in the TU engined 206s to keep insurance down for what was intended to be a cheap car en masse
