Latest: morgan20
Overall: 17135
Online Now [1457]:
Visitors: 1456
Today: 23900
Total: 110735397
Forums › The Car › 206 Problems › Central Locking from inside?
lssrules123
PostPosted: Fri Jan 20, 2012 5:39 pm Up
Hi Guys and Gals
My 206 GLX has a problem where you cannot do the central locking from inside the car, it works fine from the plip key (all doors lock plus boot) but not from the inside, it also works when I lock the car manually with the key in the door. When I push the pin down on the drivers or passenger side door, the central locking does not work...... (it only locks that door)
I want to know if anyone else has had this problem and if it is an easy fix (just a fuse?)
my car is multiplexed- if this helps
Thanks, Jason (first post!! Very Happy )
PostPosted: Fri Jan 20, 2012 5:45 pm Up
Use the lock button on the dash Wink
lssrules123
PostPosted: Fri Jan 20, 2012 6:17 pm Up
Mines an early 2002 car so it doesn't have the lock button... just the hazard button
also after searching through posts, my locks don't bounce back up after locking with the key- it just doesn't work from the door pins inside, so i don't think its a solenoid problem. Could it be a fuse problem?
PostPosted: Fri Jan 20, 2012 6:20 pm Up
Someone's changed the button I bet.
PostPosted: Fri Jan 20, 2012 6:21 pm Up
What He Said
Should be lock / hazard button with the alarm led inside fitted.
GLX WONT lock from the internal lock pins, its just not designed to.
lssrules123
PostPosted: Fri Jan 20, 2012 6:26 pm Up
should it? I though the early cars (Phase 1) didn't have the second button for the locks
PostPosted: Fri Jan 20, 2012 6:30 pm Up
Mine did from the factory.
Whats the VIN?, im on Service Box at the moment, ill look the car up & see what button it rolled out the factory with Laughing
£32.36 for the double locking button from Peugeot Shocked
lssrules123
PostPosted: Fri Jan 20, 2012 6:35 pm Up
I PMed you Very Happy
thanks btw
PostPosted: Fri Jan 20, 2012 6:38 pm Up
Im shocked, it did indead have just the normal standard hazard button fitted at the factory.
Could always pick a double button up on here / scarp yard / Ebay etc, knowing Peugeot it will want the BSI config tweaking Laughing
lssrules123
PostPosted: Fri Jan 20, 2012 6:40 pm Up
So there is no way of activating the central locking from the inside?
and if I do get hold of a switch will it just work when I connect it or will it need activating?
PostPosted: Fri Jan 20, 2012 6:42 pm Up
Must have had a new door then.
PostPosted: Fri Jan 20, 2012 6:43 pm Up
No idea on first question, sorry.
It will most likely need activating if you fit the double button.
My 03 GLX has the double button as standard, you can also set the moition autolocking with it.
Mine if you press the lock pin down it will only lock that door, if you want them all locked you have to press the dash button OR drive of to autolock.
skard
PostPosted: Fri Jan 20, 2012 6:45 pm Up
i tried a double switch in a 53 'look' and there was no way to activate it in PP2000, hazard part worked as normal
lssrules123
PostPosted: Fri Jan 20, 2012 6:48 pm Up
ok thanks for all the help guys!! Very Happy
but does anyone else know how a GLX phase 1, multiplexed, without dash double locking button can do central locking from the inside?
god this is complicated.... Confused
PostPosted: Fri Jan 20, 2012 6:51 pm Up
Just had a look & lssrules123 GLX 2002 has a different BSI unit to my 2003 GLX Confused
