Latest: jackrox1992
Overall: 17186
Online Now [1020]:
Visitors: 1019
Today: 117826
Total: 148880061
Forums › The Car › 206 Problems › airbag light on?
airbag light on?
olly
PostPosted: Thu Jan 12, 2012 2:58 pm Up
Hi all can someone tell me if by connecting a diagnostic software to my 206,will it tell me where the fault is with the airbag,so I can get it repaired? Obviously there are a number of connections linked to the airbag,so want to know will it pinpoint the fault. Cheers.
bcfc
PostPosted: Thu Jan 12, 2012 3:00 pm Up
If you use the CORRECT diagnostic kit, then YES.
PostPosted: Thu Jan 12, 2012 3:02 pm Up
Check all of the connections first much cheaper and easier
BobGTi206!xx
PostPosted: Thu Jan 12, 2012 3:08 pm Up
diagnostics have a seperate file to go into airbag faults instantly so should be a simple diagnostic and they should be able to pinpoint it directly but im not 100% sure but i think There is a connection under the drivers
seat where the Seat Belt Pretensioner is linked in, this connection may need re-doing you might be lucky and get away with cleaning the connector out and reconnecting dont hold me to it im not 100% sure if thats any help at all
“If everything seems under control, you\'re just not going fast enough. Remember A Careful Driver Is One Who Honks His Horn When He Goes Through A Red Light”
PostPosted: Thu Jan 12, 2012 3:10 pm Up
NOT on a 206 there isnt, Peugeot / Citroen had already fixed that issue Wink
Only SRS plug you might find under there is for side seat airbags if fitted.
BobGTi206!xx
PostPosted: Thu Jan 12, 2012 3:22 pm Up
ahh my bad my mate owns a 206 and said that there were so i took his word for it my badd
PostPosted: Thu Jan 12, 2012 3:40 pm Up
It was a common issue on older PSA stuff with the buckle type pretensioner.
206 the pyrotechnic seatbelt pretensioners are on the actual seatbelt reel in the B pillar.
m4tth3w
PostPosted: Thu Jan 12, 2012 7:44 pm Up
my side airbag was lighting up, disconnected red and green under seats and reconnected and stops for a bit then comes on again.
Reconnected while engine running then restarted and so far so good no airbag light..
Try it, it costs nothing.
PostPosted: Fri Jan 13, 2012 4:14 am Up
Shouldnt mess with the SRS system with the ignition on! Shocked
PostPosted: Fri Jan 13, 2012 4:16 am Up
No, he really should. He should also set up a video to record him doing it. Wink
PostPosted: Fri Jan 13, 2012 4:21 am Up
Ill have to record the lads at the garage when they scrap the next car, you can have lots of fun with airbags / pretensioners Laughing
Have to make the car safe for recycling Whistle...
olly
PostPosted: Fri Jan 13, 2012 11:06 am Up
Ah good anyone on here in the west midlands do airbag diagnostic reading....??
its been like it 2 years now,and did not realise they do not activate in a crash if the warning light is on,and with it also being an mot fail very soon.
bcfc
PostPosted: Fri Jan 13, 2012 11:12 am Up
PM Lee
Spot on lad, think he charges £20 and is based in Sheffield. Will come to you for alittle fee and all. Smile
skard
PostPosted: Fri Jan 13, 2012 11:17 am Up
you just missed out on a pug diagnostic interface i sold on here earlier in the week.
i recently had to clear an airbag fault, typically came up for the first time when it was advertised.
what it was - when i removed the stereo and put original back in or when taking out handsfree etc, i somehow nudged the passenger airbag clip under the steering wheel.
i pushed it back tightly even though it felt 'in' anyway and the fault went away. the plugs are known to be very fickle on airbag systems.
olly
PostPosted: Fri Jan 13, 2012 12:26 pm Up
Will the diagnostic check report if there are error codes/crash reports within the module,if so i can get them reset for £30.
bcfc
