Latest: Beduff1977
Overall: 17134
Online Now [373]:
Visitors: 372
Today: 116025
Total: 106976495
Forums › The Car › 206 Problems › high pitched squealling
paz216
PostPosted: Fri Jan 27, 2012 10:17 am Up
recently changed my discs and pads on my 1.4, when putting them back together i made sure to put a generous amount of copper grease over the back of the pad and the ears, to stop them squealing, however when i drive i get a squealling noise from the front, if i turn the wheel left or right the noise stops, along with when i break, anyone got any ideas what this is and how to stop it???
p.snowdon
PostPosted: Fri Jan 27, 2012 10:31 am Up
You have to clean the cylinder that is covered with rubber,when you open the calipers to take the brake pads off,pull the cylinder that the 13mm bolt attached to,you will see it's full of dirt and grim from brakes,and also you can clean the cylinder that push the pads,i will give you a link in a min.
PostPosted: Fri Jan 27, 2012 10:39 am Up
Take a look at this :
my206xr.blogspot.com/2...rvice.html
PostPosted: Fri Jan 27, 2012 11:26 am Up
did you wind the piston all the way back?
