Online Now [127]:
Visitors: 126
Today: 48093
Total: 138978616
Forums › The Car › 206 Problems › Heater Problem
Heater Problem
Seyah
PostPosted: Fri Jan 27, 2012 2:36 pm Up
Hey guys, first post.
I have a 2000 1.9 Diesel.
Recently the heater has stopped working properly. Only kicks heat out when i go above 3000 revs, for a short while, but goes cold as i drive normaly again.
I'm thinking there is a blockage somewhere, but any advice would be helpful. Tried searching but search isnt the friendliest on this forum Razz
RAWR!
marrygold75
PostPosted: Fri Jan 27, 2012 3:23 pm Up
i would be thinking air in the system,or a new thermostat.
have a nice day
PostPosted: Fri Jan 27, 2012 3:26 pm Up
make sure you have water, when mines low it goes hot and cold alot,
bleed the system also in case there is air in there.
Seyah
PostPosted: Sun Jan 29, 2012 12:13 pm Up
Cheers guys. Gonna tackle the problem tomorrow. Aswell as replacing the cig lighter socket.
Then i might have heat...when I can get it to start...but thats another problem!
RAWR!
