Posted: Tue Jan 31, 2012 3:54 pm |
Hey guys,so i just got myself some phillips xtreme power h1 on my angels..fitted smooth and smooth.
However i been fiddling with the angles etc try improve it,which took awhile on one side,so i went and fit the bulbs on passenger.
Done that,tried fitting headlight back in and i think i might of nudged something in passenger side but i don't think its possible that it cut out the entire battery to lead me to not start the engine. :S
I thought it be a loose cable thats pre-attached to car like on my driver side i might of nudged,so i left it and fit it.
Engine wouldn't start at all,i did however have a error code on my dash saying something electrical low or something?
What you think problem could be?? I had to jump start the battery which led to the car starting up..
You think it could be battery needs replacing or could be something i nudged in passenger side when installing headlights back in.
However before on driver side the same cable that powered both main and full beam did not work,but on the passenger side it does.
Now the driver side none of the beams work on my crystals,so i had to switch back to angels which lead same problem i had begin with on driver side before..
What you guys think problem be? Battery problem or actual electrical fault?
Posted: Tue Jan 31, 2012 5:16 pm |
Isnt there an earth behind the headlight points? Did you connect it back up?
Posted: Tue Jan 31, 2012 5:22 pm |
Being moron i didn't think it would of touched where exactly is the earth cable behind the passenger headlights?? It doesn't change my electrical fault in general with my headlights though =/
Most likely solve my engine starting up again but not my headlights.
Posted: Tue Jan 31, 2012 6:24 pm |
Update,car works perfectly okay now,although i just saw my multidisplay saying remote central electric or battery low what does that mean?? Would it be the car battery or my key battery?
Would you guys recommend a new car battery since i haven't had it changed since purchase,when my brother drove it back in 2007?
