Online Now [353]:
Visitors: 352
Today: 48377
Total: 105311650
Forums › The Car › 206 Problems › Headlight problem
Headlight problem
shaunc
PostPosted: Tue Jan 31, 2012 3:45 pm Up
(Tried to search this problem in previous posts and cant seem to find a topic with exactly the same problem)
Got a problem with my offside headlight.
About a week ago the bulb seems to have blown so I bought a new one and once changed it was still not working, so I have tried another bulb and checked the fuses under steering wheel and seems fine there. Also had a good look at the bulb connector and headlight wiring loom for any obvious breakages and cant see anything there.
Any ideas anyone? Confused
*ps - It doesn't work on dipped beam or full beam but separate sidelight bulb works fine
>>206 project soon to be started!
lmilligan
PostPosted: Tue Jan 31, 2012 3:48 pm Up
You sure your looking in the right place? My fuses for headlights are in the fuse box in the engine bay.
shaunc
PostPosted: Wed Feb 01, 2012 12:35 pm Up
yer checked both and all seem to be ok, but also im a bit confused because the engine fuse box has 1 fuse for both headlights main and dipped beam, and iterior fuse box has seperate fuses for each headlight.
Right? Confused
g5hawk
PostPosted: Sun Feb 12, 2012 11:47 am Up
I had the same issue and discovered that my cabin fuse box was on upside down compared to the diagrams in the book. Howd you fare sorting it out?
