Latest: airmastertapes
Overall: 17133
Online Now [1151]:
Visitors: 1150
Today: 51425
Total: 106763313
Forums › The Car › 206 Problems › 206 axles
206 axles
john206gti
PostPosted: Wed Feb 01, 2012 2:03 pm Up
Ive got a pre-plex gti 138 with movement in the trailing arm.
I can get a mint non abs drum axle for free off a damaged car.
Now if i convert it to a disc axle using parts off my gti axle, does it matter that its non abs?
john
2001 moonstone gti, gt bumpers, gen2 k&n induction kit, lightened flywheel, lowered 35mm,
PostPosted: Wed Feb 01, 2012 2:05 pm Up
it doesn't matter
PostPosted: Wed Feb 01, 2012 2:20 pm Up
Seabook wrote:
it doesn't matter
It will, the non abs axle wont have the fitments for the abs, and you will get an abs fault.
PostPosted: Wed Feb 01, 2012 3:40 pm Up
Steve206 wrote:
Seabook wrote:
it doesn't matter
he just said he will swap the trailing arm...
i though the slot was on the arm ?
PostPosted: Wed Feb 01, 2012 7:14 pm Up
If your removing the abs then you wont pass the next mot.
PostPosted: Thu Feb 02, 2012 1:10 am Up
If your swapping parts then it will be fine. Missed that part.
john206gti
PostPosted: Thu Feb 02, 2012 12:18 pm Up
I only want to use the main beam off the drum axle.
with trailing arms, torsion bars and arb off the gti axle.
Thought it would be ok but wanted to make sure before the 'big hammer' came out.
cheers
PostPosted: Thu Feb 02, 2012 12:33 pm Up
cheers
it will be fine
PostPosted: Thu Feb 02, 2012 12:34 pm Up
why would he want to remove the abs? Laughing
vwaudi
PostPosted: Tue Mar 19, 2013 4:50 pm Up
has anyone converted a non ABS to ABS by drilling the holes for the sensors?
hello
