Online Now [563]:
Visitors: 562
Today: 164745
Total: 105891307
Forums › The Car › 206 Problems › Drum brakes, spring.
Fifer
PostPosted: Thu Feb 02, 2012 11:37 am Up
Changing axle bearings today. I adjusted the adjuster to fully retracted on one side. The handbrake is now going nearly fully up before engaging. I thought the adjusters were supposed to self tighten. Do they?
Also when changing drivers side axle bearings I had to remove the brake clamp that sits on top of the trailing arm. On going to put it back I noticed a spring that wasn't connected. I think this goes through a hole in the bracket but am not sure. Can anybody confirm? Their isnt one on the passenger side so can't check that way.
1.4hdi 02
