Fifer wrote:
Good news.
I think the bolts stop the torsion bar from being able to slide out under vibration. I'm sure you know how likely that is to happen. However have you wiggled the washer around and did you clean out the groove and edge of washer. (Wouldn't the end plate keep it in anyway.)
They may just need retapping but I'm not sure of the size.
If its the angled bearings their is a sort of circlip that holds the bearing in the drum. Looking from the inside of the drum.
I had the same thing. Quoted 26 for new from factors. If the bit is a complete metal circle piece I believe it goes on the stub first against the rubber seal facing inwards. But can't guarantee that.
You can post new topics in this forum You can reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
Interactive software released under GNU GPL,
Code Credits,
Privacy Policy
