Latest: airmastertapes
Overall: 17133
Online Now [313]:
Visitors: 312
Today: 21710
Total: 106733628
Forums › The Car › 206 Problems › Coolant Temp Sensor - Where ?
SteveTDCi
PostPosted: Wed Jan 25, 2012 3:14 am Up
Ok where is it, does it fit the the thermostat housing (brown) or does it sit in the cylinder head close to the thermostat (green)
Steve
206 1.4 LX ... its called Vera and is built for abuse, but needs a few things, including hoovering out
gixxerkev
PostPosted: Wed Jan 25, 2012 4:11 am Up
What engine have you got? that might help!!
An Ex '03 1.4 GLX driver, German technology all the way now.
SteveTDCi
PostPosted: Wed Jan 25, 2012 4:31 am Up
1.4 8v 1999 Smile doh Smile
gixxerkev
PostPosted: Wed Jan 25, 2012 4:35 am Up
Its the green sensor above the thermostat housing next to the rocker cover (2 wires going to it)
SteveTDCi
PostPosted: Wed Jan 25, 2012 4:53 am Up
Thanks Smile any idea what the brown one is ? its also 2 wires
gixxerkev
PostPosted: Wed Jan 25, 2012 4:58 am Up
Just looked at my engine and cant see a brown sensor in the vacinity, so no idea, sorry.
SteveTDCi
PostPosted: Wed Jan 25, 2012 5:25 am Up
you can just see mine here - below the green sensor.
gixxerkev
PostPosted: Wed Jan 25, 2012 7:04 am Up
Nope, I haven't got one of those, I've just got a blank in the top of the thermostat housing. I'm sure someone else on here will be able to tell you what it is. Sorry I cant be of any more assistance.
PostPosted: Wed Jan 25, 2012 8:10 am Up
Coolant temp sensor=Green sensor on the top of the thermostat housing like the one in pic. Above,why you wanna know,got problems with car temp?
PostPosted: Wed Jan 25, 2012 10:48 am Up
Brown one is for the cooling fan / aircon Wink
Some 206's have 2 coolant temp sensors fitted, others just need the 1.
PostPosted: Fri Feb 03, 2012 5:40 pm Up
My daughter has a 1.4LX. The green sensor is engine coolant to ECU. Disconnect this and revs will rise but gauge is not affected.
There is a blue sensor screwed into the head below and slightly behind that green sensor and just below the air intake pipe. It is a bugger to see and get at! This blue sensor sends it's signal to the temperature gauge.
It is NOT the blue sensor that is easily visible in your picture.
MrBSI is correct about the brown sensor. That switches the cooling fan on at low speed when the aircon is switched on.
SteveTDCi
PostPosted: Sat Feb 04, 2012 3:42 am Up
Thanks, I've replaced it now, I need to fix the exhaust now, change the plugs and air filter, it sounds like its blowing and the baffles are loose Smile
