Posted: Sat Feb 04, 2012 4:50 am |
A while back my headlight connectors were melting due to the idiot I brought the car off using bulbs that were for off road use. So I bought sum new h7 connectors of eBay and tried replacing them as a straight swap however my bulbs do not work.
The original off road bulbs were working fine but then whenever I went over a bump they go off but could've wiggled back into place and work again this Is when I notice the connectors and decided to replace them. Bunks I have no lights the full beam are still Woking fine justno headlights?
What fuses/relays should I check to make sure they working?
Any help greatly appreciated
| | ![](images/spacer.gif) |
Posted: Sat Feb 04, 2012 6:46 am |
Look in your car handbook.
Posted: Sat Feb 04, 2012 6:56 am |
Check your fuses, table of them can be found in your owners manuel. Have you replaced the damaged wiring?
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport ![Cool Cool](images/smiles/icon_cool.gif) | |
Posted: Sat Feb 04, 2012 11:49 am |
I have replaced wiring but doesn't work
