Online Now [232]:
Visitors: 231
Today: 53990
Total: 142675356
Forums › The Car › 206 Problems › P****d off!
P****d off!
LeeMaddern
PostPosted: Tue Feb 07, 2012 2:34 pm Up
Okay so today i took delivery of my new bilstein shockers.
All was great untill fitting them, firstly there abit longer than normal which wasnt so bad. The part were the drop links connect to the shocker is way to long and catches on the inside of the engine bay
Its about 10mm to long!
Any ideas anyone ?
More photos on FaceBook - www.facebook.com/lmaddern1
Dabamash
PostPosted: Tue Feb 07, 2012 2:41 pm Up
Staff - Daba
Stihl Saw?
PostPosted: Tue Feb 07, 2012 2:43 pm Up
Call the company where you got them from and ask them simple
jimjam19927
PostPosted: Tue Feb 07, 2012 2:54 pm Up
Sure they sent you the correct part?
Member: 685
I Over Use Smilies Razz
LeeMaddern
PostPosted: Tue Feb 07, 2012 2:55 pm Up
There brand new but i bought them from an ebayer they hadn't even opens them
Seriously p**sed off :/
LeeMaddern
PostPosted: Tue Feb 07, 2012 2:56 pm Up
Shouldnt have to saw somthing which is made to fit your car
LeeMaddern
PostPosted: Tue Feb 07, 2012 2:57 pm Up
Thats the only thing i can think off :/
PostPosted: Tue Feb 07, 2012 2:59 pm Up
Send them back open a dispute for item not as dscribed.
LeeMaddern
PostPosted: Tue Feb 07, 2012 3:02 pm Up
Cross referenced the part number and it says it for a peugeot 206.
Lecktorious
PostPosted: Tue Feb 07, 2012 3:08 pm Up
Trade Rating: +59
Should you not be ftting shortened shocks to match the springs?
'98 Nile Blue 306 GTi 6
Ste
PostPosted: Tue Feb 07, 2012 3:33 pm Up
Staff - Ste
They look fine to me, exactly like my old Bilstein's, I cant see why the droplink connector would catch tbh mate, are you sure your fitting the shockers on the correct side of the car, as they are side dependant?
Do note though that if the springs are over a 30mm drop the shocks have the potential to bottom out as they're not shortened shocks..
If you look on the sticker on the shocks they should tell you which side they need to be fitted on mate, have a wee peak at them and make sure you were fitting them to the correct side, this isnt aimed at been undermining, it's just I've seen people fit them on the wrong side before and it's something that's sometimes overlooked.
The Cars:
PostPosted: Tue Feb 07, 2012 3:37 pm Up
grind it off. job done.
who need anti roll bar?
PostPosted: Tue Feb 07, 2012 4:05 pm Up
I have those (B4's) fitted for the past year and I'm about to bin them and get genuine pug ones instead.
It just did not work for me at all.
Far-far too soft, way softer than OEM, banging on the out-stroke and the worst part:
oscilating and resonance on minor road surface uneveness.
Total fiasco but my mech had warned me that I would bitterly regret fitting them.
Might as well have kept the OEM worn ones for sure.
PostPosted: Tue Feb 07, 2012 4:57 pm Up
As said, they should fit without coming near to the inside edge of the wheel space. Were they unopened in box?
LeeMaddern
PostPosted: Tue Feb 07, 2012 5:46 pm Up
Yeah they were unopend mate
