Latest: jackrox1992
Overall: 17186
Online Now [1064]:
Visitors: 1063
Today: 101813
Total: 148865320
Forums › The Car › 206 Problems › Windscreen wipers
Windscreen wipers
Frost
PostPosted: Fri Feb 10, 2012 1:30 pm Up
So mine were crap so i went and brught a set of flat blade ones, thes didn't touch the edges of the screen so i assumed it was just the flat blade ones, i've just been out and brought a standard pair and am having the same problem Sad any idea or do i have to go direct to peugeot and but them at £15 a side?
I'm going to take the new ones back and complain that they don't fit the windscreen and try and get my money back
"if someone has put it together then I will take it apart" it might never work again but at least I will have an understanding of how it worked and might be able to buy another
The voices in my head may not be real, but they have some good ideas!!
PostPosted: Fri Feb 10, 2012 1:32 pm Up
Sounds about right no problem with them.
What size did you get in the flat blades?
Matt
PostPosted: Fri Feb 10, 2012 1:55 pm Up
Trade Rating: +32
For normal blades you need 22" for passenger side and 21" for drivers side.
Frost
PostPosted: Fri Feb 10, 2012 2:09 pm Up
They were 22/22S Smile but about an inch of the blades are not being used, i'll take them back and get a smaller one on the drivers side, but if i get a smaller size will it still clear the rain sensor?
PostPosted: Fri Feb 10, 2012 2:30 pm Up
The problem your asking about is NORMAL for the 206 windscreen, there's NOTHING wrong with it, its just a quirk of the design curve of the glass.
Frost
PostPosted: Fri Feb 10, 2012 2:32 pm Up
So it won't fail the MOT because it doesn't clear the windscreen effectivly?
PostPosted: Fri Feb 10, 2012 2:35 pm Up
Its only about the first 9" / 12" inches right on the end of the blades sweep on the edge of the drivers side of the screen.
Its a built in design quirk Wink
