Latest: KevinRC
Overall: 17137
Online Now [771]:
Visitors: 770
Today: 44658
Total: 111186104
Forums › The Car › 206 Problems › ABS mot....Help!!
ABS mot....Help!!
heppy1
PostPosted: Wed Feb 08, 2012 2:43 pm Up
Hi i bought a 206 1.6 xs 2000 model few month back and just put it in for a MOT.It failed because abs light wouldnt eliminate.Mechancic told me someone has removed the bulb.He now informs me my car should have discs on the back not drums... he rekons the axle has been changed and no abs to rear now.Can anyone tell me if my car should have discs on the back or not.Thanks Confused
PostPosted: Wed Feb 08, 2012 2:47 pm Up
need VIN to confirm that.
but as far as i remember most XS has rear drum brake
heppy1
PostPosted: Wed Feb 08, 2012 2:52 pm Up
vin is VF32CNFZE40993040 Cheers
206xs
PostPosted: Wed Feb 08, 2012 2:59 pm Up
you got drum brakes with ABS
heppy1
PostPosted: Wed Feb 08, 2012 3:44 pm Up
ok someone has obviously disconected wires for them as there is no signs of anything.Would wires go to both back drums?
206xs
PostPosted: Wed Feb 08, 2012 4:07 pm Up
no idea as i don't have abs...
but it could be the front too, if you get the code read it should tell you which side has the problem
heppy1
PostPosted: Thu Feb 09, 2012 2:08 pm Up
does abs have to have 4 wheels to work or can it still work with just front discs and rear drums?
206xs
PostPosted: Thu Feb 09, 2012 2:56 pm Up
If it works or not it is out of the question, you will need all four corners functioning to pass the mot.
