Latest: sparrowdclxvi
Overall: 17139
Online Now [484]:
Visitors: 483
Today: 125566
Total: 112809438
Forums › The Car › 206 Talk › phase 1 lights tail bulbs
omricn
PostPosted: Fri Feb 10, 2012 6:18 am Up
I'm looking to change my tail (reverse, brake\tail) bulbs, the reverse bulbs are not a problem, got some p21w's, but I don't know whether I should get white OR red tail\brake led bulbs??? help...
gazza82
PostPosted: Fri Feb 10, 2012 6:57 am Up
phase 1 lights ... clear are fine
omricn
PostPosted: Fri Feb 10, 2012 8:15 am Up
Thanks for answering mate, Won't the white led's emit a white'ish hue through the red plastic? And on the other side will red led's be too weak through the red plastic? Guess I'm looking for someone who already fitted some..
omricn
PostPosted: Fri Feb 10, 2012 12:13 pm Up
Went with the red ones, heard the white ones give a pinkish hue 
gazza82
PostPosted: Sun Feb 12, 2012 7:59 am Up
I didn't see the LED reference ... your heading said Bulbs ...
If you use bulbs in the Phase 1 lights, then clear are OK
If you swap to LED's then you should use the same colours as the lens: red for brakes and rear fogs, amber for indicator, white for reverse.
omricn
PostPosted: Sun Feb 12, 2012 2:10 pm Up
Actually what I meant was replacing the bulbs inside my phase 1's from regular to LED's, cheers for the replys mate
