Posted: Sat Feb 11, 2012 3:42 am |
| >>206 project soon to be started! | |
Posted: Sat Feb 11, 2012 4:13 am |
Is the boot flushed? kind of looks like it is.
If not just get a second hand tailgate for 30 quid
Posted: Sat Feb 11, 2012 4:35 am |
No its not flushed, that was gonna be the next step after fixing this and spraying my new bumper.... I thought that would be the reply to be honest, so back to the scrapyard then!
Posted: Sat Feb 11, 2012 4:47 am |
this is quite common....
Posted: Sat Feb 11, 2012 4:49 am |
Its a known 206 issue on a certain batch of cars due to a c**k up at the factory when the rear screen was incorrectly fitted.
Good 2nd hand tailgate in the correct colour is the ONLY cure for this.
Posted: Sat Feb 11, 2012 4:52 am |
MrBSI wrote: |
Good 2nd hand tailgate in the correct colour is the ONLY cure for this. |
ok...
does it limited to phase 1 tailgate only then?
Posted: Sat Feb 11, 2012 5:10 am |
You could always sand it down and put that stuff on it that changes the rust to metal again and respray it?
Cant remember what the stuffs called.
Although unless you can spray yourself, would probably be cheaper to just get another tailgate.
Posted: Sat Feb 11, 2012 5:17 am |
MrBSI wrote: |
Yer that's the problem, finding a decent one in the right colour. It was hard enough finding a decent bonnet in the right colour! :/
Ahhhr well best get searching, thanks for the advice
Posted: Sat Feb 11, 2012 5:18 am |
Why not look out for a 2nd hand tailgate with a spoiler and upgrade at the same time has to be the easiest way to DIY the rust and you upgrade at the same time did it with a friend off of here took an hour tops to swap everything over!
Posted: Sat Feb 11, 2012 7:12 am |
i agree will dillon and go for a phase 2 one as they dont seem to go like this
Posted: Sat Feb 11, 2012 7:37 am |
I can spray myself to a certain extent but its the place which is abit of a sod
I've already got a spoiler I'm plannin to spray and bolt on but I supose if I get an ugraded one it will have the better lookin boot strip
Posted: Sat Feb 11, 2012 8:47 am |
shaunc wrote: |
I've already got a spoiler I'm plannin to spray and bolt on but I supose if I get an ugraded one it will have the better lookin boot strip |
Replace the tailgate, dont bother trying to repair the rust as it will only come back again sooner or later.
It will be far cheaper & easier to keep an eye out for a replacement tailgate then trying to repair that one as the rear window which is bonded in will need removing to do a proper repair.
