Online Now [591]:
Visitors: 590
Today: 605
Total: 106337862
Forums › The Car › 206 Problems › Air con pump
Air con pump
Ash_guff
PostPosted: Fri Feb 17, 2012 7:00 am Up
Could anyone help me,my aircon pump is wining so needs replacing iv found a 2nd hand 1 but its off an 02 1.4 quicksilver would this be the same as whats on my 1999 gti?
IF IT BREAKS,IT BREAKS,ITS FRENCH!
PostPosted: Fri Feb 17, 2012 7:38 am Up
I've got one sat redundant from my gti if it's of any use?
Ash_guff
PostPosted: Fri Feb 17, 2012 8:03 am Up
Where abouts are u bud?
PostPosted: Fri Feb 17, 2012 9:57 am Up
St Anne's next door to Blackpool. I took it off during the summer as my plans meant there would be no space for air con parts. Before it was removed my air con worked perfectly even at ten years old.
How does £40 delivered sound? It's quite heavy so postage will be a few quid.
