Posted: Sat Mar 10, 2012 12:32 pm |
with what a hacksaw ?
Posted: Sat Mar 10, 2012 12:52 pm |
Angle grinder
Posted: Sat Mar 10, 2012 12:57 pm |
oh not exactly in my toolkit lol
Posted: Sat Mar 10, 2012 1:00 pm |
Borrow one or go buy one from b&q there cheap enough
Posted: Sat Mar 10, 2012 1:01 pm |
you could drill the thread out i had to do this on my old 406 took some time
Posted: Sun Mar 11, 2012 7:10 am |
Second attempt with mole grips and wouldn't grip thread without it turning so no luck, got the rear brake calipers and pads off then seen a yet another torx screw holding the disc in that wouldn't budge. Whoever engineered this torx fitting needs to be shot ... Why can't they be like Ford or BMW oh i forgot its f**** peugot.
Posted: Sun Mar 11, 2012 9:21 am |
Linkpad wrote: |
Whoever engineered this torx fitting needs to be shot ... Why can't they be like Ford or BMW oh i forgot its f**** peugot. |
Torx fittings have been around for 45 years.
Disc screw = impact driver OR if you havent got one put the torx bit in the screw head & hit it hard several times with a hammer BEFORE you attempt to undo it.
Posted: Sun Mar 11, 2012 10:32 am |
A small hacksaw is perfectly adequate.
Posted: Sun Mar 11, 2012 11:49 am |
i just remember other cars ive been on they had standard screw fittings, as for the drop links most other cars have a bolt or fixing to anchor down on the opposite end.
edward u reckon a small hacksaw would take the bolt off a drop link, i cant see that working ?
I tried hammering the torx screw on the disc, looks like an impact torx is best option. Why oh Why did i buy a 206.
Posted: Sun Mar 11, 2012 11:55 am |
Genuine Peugeot drop links will have spanner flats on the threaded stud to stop the ball joint turning as you undo the nyloc nut.
Posted: Sun Mar 11, 2012 1:36 pm |
You cut the nut off the droplink. Just slice a side off it.
Posted: Sun Mar 11, 2012 1:53 pm |
aah cheers ill try that with a hacksaw, and get impact driver for the rear discs
Posted: Tue Mar 13, 2012 12:18 pm |
3rd attempt at taking that god damn nut off the drop links this time with a hacksaw and a hammer and chisel even with 1/3 of the nut cut off and chiselling it like hell the thing still won't budge... Not sure i be able to get a nut splitter over it ...
