Online Now [234]:
Visitors: 233
Today: 12859
Total: 142634700
Forums › The Car › 206 Problems › Regrets!! maybe??
Regrets!! maybe??
bakke1
PostPosted: Mon Mar 05, 2012 1:43 pm Up
HI Guys
Got my first GTI about a week ago, just wanted a run round to go back and four work, but maybe starting to regret it?
Noticing a few problems, these maybe easily solvable (hopefully). I have not got a clue with cars!!!
1 - LCD display is not working for the time, and temp etc
2 - Also the digital mileage display only sometimes shows, you can only make some numbers out
3 - When I full lock the steering wheel right or left a screeching sound can be heard and its quite loud
4 - The front window washers are not working, it sounds like the pump is working but get nothing out except the tips foam
5 - Every bump and lump in the road can be felt when driving
The car is going to be looked over by a garage soon just wanted to see if other people have had similar problems
Car details
2001 Y reg
Gti standard
17 inch alloys/tyres
a rowe
AshH
PostPosted: Mon Mar 05, 2012 2:01 pm Up
1. LCD Display easily changes, should be a How To on here if you use the Search Button you can find on the top bar.
3. Could possibly be the AUX Belt, but not 100%
4. Could be a blockage in the system, poke a needle or somthing though the little holes see if that helps it, or go to your Peugeot/Citreon main dealer and ask for the Phase 2 Wash Jets from a new 206.
Hope this helps, if I'm wrong someone will correct me (y)
Team - 180
Team - ATM!!!
Ash
PostPosted: Mon Mar 05, 2012 2:06 pm Up
5. Its a Peugeot 206, not a Rolls Royce.
PostPosted: Mon Mar 05, 2012 2:07 pm Up
3- power steering pump/fluid.
4- blocked jets
5- it's a Gti.
Lecktorious
PostPosted: Mon Mar 05, 2012 2:12 pm Up
Trade Rating: +59
bakke1 wrote:
HI Guys
Car details
2001 Y reg
Gti standard
1. Faulty MFD.
2. Replace a bulb behind the display.
4. Replace the washer jets. If that doesn't work, replace the piping.
5. You have 17's fitted. Fit a proper set of wheels without a smear of rubber and you will notice an improvement. Have the suspension looked at too.
'98 Nile Blue 306 GTi 6
PostPosted: Mon Mar 05, 2012 2:45 pm Up
Didnt you test drive it first?
deanparkr
PostPosted: Mon Mar 05, 2012 3:39 pm Up
I wonder this as well.. were these things not present on the test drive?
2002 1.4LX
bakke1
PostPosted: Tue Mar 06, 2012 10:30 am Up
Thanks for getting back guys
The CAM was changed at 69k, well I got recipts to show it was anyway.
I did test drive it but none of the faults appered (other than the LCD display)
I will update the post once its been in the garage (if it gets there Laughing )
a rowe
