Latest: tbafonso
Overall: 17130
Online Now [313]:
Visitors: 312
Today: 11559
Total: 103941973
Forums › The Car › 206 Problems › GTi gearbox issues...
Go to page Previous  1, 2
PostPosted: Tue Mar 06, 2012 2:12 am Up
You don;t even need to take the gearbox out to change the synchros...stil not a job for a fast fit centre...
PostPosted: Tue Mar 06, 2012 8:12 am Up
Anybody ever changed the synchros on one of these boxes? Just looking on servicebox now the Syncro hub is £23 including vat.
PostPosted: Tue Mar 06, 2012 12:34 pm Up
Seabook wrote:
synchro is cheap....
How cheap? How big a job is it to change?
last time i check each ring is about 20-30 quid.
PostPosted: Tue Mar 06, 2012 12:39 pm Up
not that difficult if you can drop the box and re-fit it.
i got a detail guide with pics.
will post it once i got back home from work.
PostPosted: Tue Mar 06, 2012 2:04 pm Up
www.rallyparts.co.uk/cwp_change/
this, very detail, step by step guide for stripping a BE box.
very useful guide when i strip the old box
PostPosted: Wed Mar 14, 2012 8:36 pm Up
Just a thought, Could it be an issue with the clutch not dissengaging properly? Hydrolics need bleeding?
Page 2 of 2
