Latest: Kifi69
Overall: 17183
Online Now [390]:
Visitors: 389
Today: 97368
Total: 143757520
Forums › The Car › 206 Talk › tps/map sensors
tps/map sensors
jimm
PostPosted: Sat Mar 17, 2012 9:15 am Up
are the parts off e/bay ok ie throtle p/s and map sensor as i,ve just changed my coil pack and it seems to not want to excelarate now and then so i thought i,d change them also ?
do\'nt know alot
PostPosted: Sat Mar 17, 2012 9:16 am Up
Why not get it fault scanned rather than changing a load of parts you don't need? Confused
Normally overpriced or cheap Chinese crap.
You tried Peugeot?
jimm
PostPosted: Sat Mar 17, 2012 10:04 am Up
the R A C had a boat load of gadgetry on my car in january found my ecu not working and a list as long as your arm of other faults recovered my car home and the next day it started as normal and is still running but with slight probs had it scanned no faults ??????? funny that i,ll just play with it i think jim
do\'nt know alot
PostPosted: Sat Mar 17, 2012 10:06 am Up
What did you scan it with the second time?
jimm
PostPosted: Sat Mar 17, 2012 10:10 am Up
lee did yu get my message regarding the door soleniod , is on car and working ok cheers for that,,
do\'nt know alot
jimm
PostPosted: Sat Mar 17, 2012 10:13 am Up
a scanner at a garage only fault was air bag light coming on steering wheel took bulb out
do\'nt know alot
