Latest: flipflap
Overall: 17140
Online Now [394]:
Visitors: 393
Today: 17692
Total: 113817897
Forums › The Car › 206 Problems › ABS Fault/ Esp/ASP Not Functioning correctly?
T12eed
PostPosted: Wed Mar 07, 2012 12:40 pm Up
Hi All
I have "ABS Fault/ Esp/ASP Not Functioning correctly" showing up on the head up display am i right in thinking my ABS sensor is goosed?
Very occasionaly when braking it feel's the same as when you brake on ice and you get the ABS grinding noise/feel apart from that it drive's as it should.
Thanks in advance.
Like A Boss!!!
NICKST
PostPosted: Wed Mar 07, 2012 2:17 pm Up
It will be the abs rings on the cv joint will have cracked happend on my 180 and was kicking in when just brakeing normally.
PostPosted: Wed Mar 07, 2012 2:26 pm Up
Just get it code read.
If you have HID's fitted make sure the ballasts aren't near the ECU's due to the electromagnetic field.
NICKST
PostPosted: Wed Mar 07, 2012 2:46 pm Up
before paying out for have codes read just check the abs rings for cracks missing teeth i am 99% sure that's what your problem is common symptoms you will have to replace the cv joint/joints there not to expensive.
T12eed
PostPosted: Wed Mar 07, 2012 6:21 pm Up
Cheers gentlemen muchos appreciated.
Forgot to mention my car is a 206 hdi gti does the above still apply?
Also does anyone have a part number for the CV joints?
Thanks.
Like A Boss!!!
NICKST
PostPosted: Thu Mar 08, 2012 1:11 am Up
Yes still applys mate
T12eed
PostPosted: Thu Mar 08, 2012 7:00 am Up
Cheers mate, just got off the phone to the dealership and they claim you can't but the CV.joint alone apparently I have to but the full shaft is that correct?
Thanks.
Like A Boss!!!
NICKST
PostPosted: Thu Mar 08, 2012 7:09 am Up
I got just the cv joints for my 180. Ring these guys I know there nowhere near you but they will tell you I got mine off them. Manchester motor factors 0161 8700 600 and just give them your reg.
