Latest: Beduff1977
Overall: 17134
Online Now [633]:
Visitors: 632
Today: 75221
Total: 108411563
Forums › The Car › 206 Talk › What do I need to un-screw the wing mirror
Foz369
PostPosted: Thu Mar 08, 2012 11:16 am Up
My left hand wing mirrors loose and i need to un-screw it to put it back and im not sure what tool i need to do this, i think its an allen key, but im not 100%, so im wondering if you could help? Thanks
sig removed due to size
Martind
PostPosted: Thu Mar 08, 2012 11:18 am Up
Go to your car and look!
Foz369
PostPosted: Thu Mar 08, 2012 11:19 am Up
I have looked but i cant see the screw in the hole because of the angle, if it was as simple as looking i wouldnt be asking would i
Martind
PostPosted: Thu Mar 08, 2012 11:22 am Up
Look from a different angle?
Maybe a light/torch might make it a little easier?
Martind
PostPosted: Thu Mar 08, 2012 11:26 am Up
I may be being stupid here, but what is not to see?
Foz369
PostPosted: Thu Mar 08, 2012 11:50 am Up
not from there, its come loose from the bit sticking out from the car
Martind
PostPosted: Thu Mar 08, 2012 11:53 am Up
From what I read in you original post, I was thinking "How can someone not see those screws?!"
Now I understand what you mean.
Best bet would be to take the whole mirror off so you can handle it and have a good look from all angles.
Coolspot
PostPosted: Thu Mar 08, 2012 12:27 pm Up
Could be be a small torx bit like you have holding the bumpers and many other parts?
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Thu Mar 08, 2012 12:51 pm Up
T20
Foz369
PostPosted: Thu Mar 08, 2012 4:00 pm Up
Lee wrote:
T20
Will this sized one work?
20619d
PostPosted: Fri Mar 09, 2012 2:39 am Up
mine was 3 phillips screws as to mine apart 2days ago
Logan
PostPosted: Fri Mar 09, 2012 2:53 am Up
Changed mine last Monday. Remove the whole unit with a T20. All the other scews on the mirror unit are phillips.
