Posted: Fri Mar 09, 2012 3:25 pm |
Heyhey
my car failed the MOT yesterday on emissions
im unsure what else i could do it drop them i gave it a full service and even bought a new cat but the results were
FAST IDLE SPEED ( Min-2000 Max-3000 ) Actual Reading 1646 = FAIL
FAST IDLE CO % ( Max-0.30 ) Actual Data 1.61 = FAIL
SECOND FAST IDLE CO ( Max-0.30 ) Actual Data 1.19 = FAIL
IDLE CO% ( Max-0.50 ) Actual Data 3.19 = FAIL
Posted: Fri Mar 09, 2012 3:26 pm |
What did the garage suggest?
Posted: Fri Mar 09, 2012 3:27 pm |
he didnt he just mugged me off saying its like my exhaust is f****d but i fitted the new one 2 days before the mot and iv been back to the shop and they say its fine :/
Posted: Fri Mar 09, 2012 3:31 pm |
put expensive v power fuel in it drive it for 1 hr before taking it back to him and get him to retest it, that should do the trick!
Posted: Fri Mar 09, 2012 3:32 pm |
diesel or petrol?
i bought liqui moly injectors cleaner and she pass it straight thru
Posted: Fri Mar 09, 2012 3:39 pm |
petrol 2.0l gti
Posted: Fri Mar 09, 2012 3:40 pm |
put in some petrol magic and some higher octane fuel and thrash the balls off it down a motorway should clean the crap out works for me and other cars ive had
| peugeot 1.6 xs lowerd with black 15\" alloys custom chrome grill painted red dash and trim | |
Posted: Fri Mar 09, 2012 3:55 pm |
sweet cheers its in for a retest next weekend so fingers crossed
Posted: Fri Mar 09, 2012 4:09 pm |
Genuine Cat? For emmision failure i would say the cat is at fault, especially a cheaper one. any engine lights? When was the car last serviced?
Posted: Fri Mar 09, 2012 4:12 pm |
Fit a decent aftermarket exhaust and take the car to a garage that will overlook exhaust emissions!
Posted: Fri Mar 09, 2012 4:25 pm |
take it to a different mot garage
Posted: Fri Mar 09, 2012 4:36 pm |
might have to make friends with some one who can just pass me a mot
Posted: Sat Mar 10, 2012 3:00 am |
did they check the O2 sensor at all?
Posted: Sat Mar 10, 2012 5:35 am |
Yes, it's likely your lambda/o2 sensor is shafted ... was it disturbed when you had the new exhaust fitted?
Our 206CC 2.0 has two ... one pre-cat, one post-cat ... but until I get PP working I can't tell which is screwed .. one is, the code reader I have tells me!
Posted: Sat Mar 10, 2012 8:19 am |
iv been to see him today he said bring it in next weekend for the retest and he will adjust the readings for a pass
