I have just recently bought a Y reg Peugeot 206 1.4 lx model and yesterday I attempted to change my speaker. When I got the new speaker in it did not work an neither did the tweeter. So I looked at both fuse boxes and couldn't find any blown ones and then the real problems started.
I went to try and start my car and it only turns over but doesn't fire up also the electric windows,digital clock,air con and you can no longer lock it with the fob key. I have had the AA to look it and he couldn't figure it out the Ecu is fine as he ran a check and he said its best to try and get an auto electrician to look at it.
I was wanting to find solutions or if anyone else has had this problem and will it be costly to fix or even just how to sort it.
